Home » Archived » BIRT » can't create PDF output
can't create PDF output [message #1161095] Tue, 29 October 2013 15:25 Go to next message
Gibran Shah is currently offline Gibran ShahFriend
Member
I can't get PDF output to work. If I got to Run > View Report > As PDF, all I get is this:
index.php/fa/16584/0/
Can someone help me to get PDF output working.
Thank you.
Re: can't create PDF output [message #1164013 is a reply to message #1161095] Thu, 31 October 2013 11:24 Go to previous messageGo to next message
donino donino is currently offline donino doninoFriend
You don't give much informations, are there errors in birt engine logs? I assume this report is a chart, try to set the .PNG type to the chart rather than .SVG and see if it is changing something.
[Updated on: Thu, 31 October 2013 11:27]
Report message to a moderator
Re: can't create PDF output [message #1170170 is a reply to message #1164013] Mon, 04 November 2013 13:00 Go to previous message
Marina Orth is currently offline Marina OrthFriend
Member
are you sure, you are not using HTML-Elements? HTML is not shown in PDF...
Previous Topic:RHINO USAGE WARNING: Missed Context.javaToJS()
Next Topic:how to create datewise table?
Current Time: Sat Dec 21 12:44:43 GMT 2024
Powered by FUDForum. Page generated in 0.04425 seconds
