Re: How do I "overload" an already existing EditHelper? [message #114663 is a reply to message #114613] |
Tue, 27 March 2007 12:35 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Linda Damus![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ldamus%40ca.ibm.com) Messages: 85 Registered: July 2009 |
Member |
Alexander,
You can augment the command returned by an EditHelper by binding an
IEditHelperAdvice to its element type using an adviceBinding element in
the elementTypes extension point. This will result in a composite
command that contains both the command from the EditHelper in your
generated editor plugin _and_ the command from your IEditHelperAdvice.
If you wish to completely _replace_ the command from the EditHelper, you
can set the REPLACE_DEFAULT_COMMAND parameter from your
IEditHelperAdvice, like this:
request.setParameter(IEditCommandRequest.REPLACE_DEFAULT_COM MAND,
Boolean.TRUE);
There is an example of this in the
HalfAdderAdvice#getBeforeConfigureCommand in the runtime logic example.
In this example the advice is contributed by a specializationType
element in the elementTypes extension point because the half adder is a
type in its own right, but the same idea applies when you're using the
adviceBinding element.
Hope that helps,
Linda
Alexander Dotor wrote:
> Hello,
> I have a custom project for my generated GMF-editor. As my custom-plugin
> expands functionality I want to add new commands that are retrieved by
> the EditHelper.
> How do I override the already generated EditHelper. I played around with
> the type extension points, but did not recieve the desired result so
> far. I've set a break point in my new EditHelper but it is not called.
> Greetings,
> Alexander
FUDForum. Page generated in 0.03363 seconds
