Problem with a wizard and a wsdl parser [message #114170] |
Mon, 27 June 2005 13:53 |
Originally posted by: andreas140983.libero.it
Hi! I'm working in the creation of a plugin for eclipse and in particular
I use as baseline of my work the Eclipse's new Plugin Project and I have
choosen the template "Multipage Editor". In the wizard that I create, I
want that the user insert the address of a file WSDL and when he push the
Finish button the plugin invoke a WSDL parser that I have already create
and pass to it the address inserted. The code of the wizard is the same of
the template and I have only inserted the creation of the WSDL parser'
object and the call to it's method that parse the file. The problem arrive
when I run my plugin with the Run time workbench. When I try to use my
plugin, I push on New->Other.. and I select my wizard but when I push on
Next button Eclipse return me this error:
"Unhandled event loop exception
Reason:"
Is the problem inherent with the WSDLException? I have insert the throw
clause but the error remain!
I have used the wsdl4j.jar and the qname.jar but I don't say if I have to
insert these in the plugin.xml file. Please can anyone help me?
Re: Problem with a wizard and a wsdl parser [message #114445 is a reply to message #114293] |
Tue, 28 June 2005 16:48 |
Thanks, I have insert the wsdl4j jar and the qname jar in the plugin.xml
with this code:
<library name="wsdl4j.jar">
<export name="*" />
<packages prefixes=the directory of my jar file />
</library>
<library name="qname.jar">
<export name="*" />
</library>
It is correct?
Now where I can find the WTP plugin that I have to add?
Excuse me for my english but I'm italian.
Thanks!
FUDForum. Page generated in 0.04353 seconds
