Home » Modeling » M2T (model-to-text transformation) » [XPand] Programatically run Workflow
[XPand] Programatically run Workflow [message #1143505] Fri, 18 October 2013 04:22 Go to next message
my workflow;
<workflow>
	<property name="modelFile"
		value="platform:/resource/com.mdd4cca.msf.codegen/src/ArgeMerkeziPortalı.content" />
	<property name="mmPackage" value="com.mdd4cca.msf.content.ContentPackage" />
	<property name="srcGenPath" value="src-gen" />
	<property name="mainDefine" value="template::Root::main" />
	<property name="fileEncoding" value="Windows-1254" />
	<bean id="mm" class="org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel" />
	<!-- Klasor temizler. -->
	<component class="org.eclipse.emf.mwe.utils.DirectoryCleaner">
		<directory value="${srcGenPath}" />
	</component>
	<!-- Model dosyasini okur. -->
	<component class="org.eclipse.emf.mwe.utils.Reader">
		<uri value="${modelFile}" />
		<!-- Daha sonra kullanilmak uzere degisken tanimlar. -->
		<modelSlot value="model" />
	</component>
	<!-- check model -->
	<!-- <component class="org.eclipse.xtend.check.CheckComponent"> -->
	<!-- <metaModel idRef="mm" /> -->
	<!-- <checkFile value="metamodel::Checks" /> -->
	<!-- <emfAllChildrenSlot value="model" /> -->
	<!-- </component> -->
	<component class="org.eclipse.xpand2.Generator">
		<expand value="${mainDefine} FOR model" />
		<outlet path="${srcGenPath}/">
			<postprocessor class="output.CSharpBeautifier" />
		</outlet>
		<resourceManager
			class="org.eclipse.xtend.expression.ResourceManagerDefaultImpl">
			<fileEncoding value="${fileEncoding}" />
		</resourceManager>
	</component>
</workflow>
and when i run this workflow on runtime-eclipse via command i always get
"[ERROR]: No Definition 'template::Root::main for ..."
why i get this don't understand
anyone can help me ?
P.S i use doRun() method on Kepler
Re: [XPand] Programatically run Workflow [message #1143766 is a reply to message #1143505] Fri, 18 October 2013 08:08 Go to previous messageGo to next message
Your resource manager won't be able to load the resource from the classpath. This is how the default implementation works, which is used in standalone mode. Likely you will find that ResourceManagerDefaultImpl#loadResource() will return null.
When running in a plugin, use the XpandPluginExecutionContext instead of XpandExecutionContextImpl. This registers a special resource manager, the PluginResourceManager.
~Karsten
Re: [XPand] Programatically run Workflow [message #1148193 is a reply to message #1143766] Mon, 21 October 2013 06:34 Go to previous messageGo to next message
Thanks for the answer.
As far as I know, It worked perfectly in Juno.
XpandPluginExecutionContext requires IXtendXpandProject object as a constructor parameter. How can I get IXtendXpandProject(or IProject) for an installed plugin?
Thank you.
Sincerely.
Re: [XPand] Programatically run Workflow [message #1186135 is a reply to message #1148193] Thu, 14 November 2013 09:00 Go to previous messageGo to next message
By the way, I want to execute my template on Runtime Eclipse. Is "XpandPluginExecutionContext" right for my situation?
Thanks.
Re: [XPand] Programatically run Workflow [message #1219653 is a reply to message #1186135] Thu, 05 December 2013 04:00 Go to previous message
Hi.
I solved the problem by changing package name workflow to a more qualified name com.akgun.workflow.
Previous Topic:[Xpand] C postprocessor
Next Topic:[Xpand/MWE] Scoping of global variables and element properties
Current Time: Wed Mar 12 15:57:44 EDT 2025
Powered by FUDForum. Page generated in 0.03160 seconds
