help with COSMOS_DG_Constructing_a_Data_Manager [message #10784] |
Fri, 04 July 2008 00:03 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Nithya![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=nithyats82%40yahoo.com) Messages: 10 Registered: July 2009 |
We are trying to Run our MDR in Eclipse follwing the instructions in
http://wiki.eclipse.org/COSMOS_DG_Constructing_a_Data_Manage r.
We have followed all the steps in this document. However, when I
rightclick--> run on server, I get the following message in the console :
[INFO] Trouble processing wsdl file :No service was not found in the WSDL
at
file:/C:/eclipse-SDK-3.4M6-win32/eclipse/.metadata/.plugins/ org.eclipse.wst.server.core/tmp0/wtpwebapps/org.eclipse.cosm os.example.mdr/WEB-INF/services/StudentTeacherSample/META-IN F/
with targetnamespace http://cmdbf.org/schema/1-0-0/query
The wsdl does not open up.
We are new to SOA, and are not sure on what is causing this error. The
service element looks like this as of now in wsdl :
<wsdl:service name="newLine">
<wsdl:port name="MfloMDRQueryService" binding="tns:QueryBinding">
<soap:address location="TO_BE_GENERATED"/>
</wsdl:port>
</wsdl:service>
Are there additional steps( in addition to those listed in the
COSMOS_DG_Constructing_a_Data_Manager) that is needed to generate the
right wsdl file?
We tried generating the wsdl automatically by setting
<parameter name="useOriginalwsdl">false</parameter>. This geneartes a
wsdl, however I am not able to access the EPR from the client.
NithyaHello,
at
</wsdl:port>
</wsdl:service>
right wsdl file?
Nithya
Re: help with COSMOS_DG_Constructing_a_Data_Manager [message #11835 is a reply to message #11762] |
Fri, 14 November 2008 04:22 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: david_whiteman.us.ibm.com
Hi vinesh,
Have you confirmed that you are using the latest version of the code &
the documentation? The documentation found on the wiki pages is obsolete.
David
vinesh wrote:
> I've created a Student Teacher MDR by follwing the steps provided in the
> devguide, but when I run the same it is giving tthe follwoing error in
> the console
> Trouble processing wsdl file :No service was not found in the WSDL at
> .../org.eclipse.wst.server.core/tmp0/wtpwebapps/org.eclipse. cosmos.example.mdr/WEB-INF/services/StudentTeacherSample/MET A-INF/
> How can I resovle this issue, pls let me know.
> vinesh.
FUDForum. Page generated in 0.04198 seconds
