RAP deployment [message #112527] |
Mon, 17 November 2008 05:00  |
I have been worked for three days on the RAP deployment of the demo.
Without success.
I'm referring to
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.rap.help/help/html/intro.html
I tried it step by step and several times, but it doesn't work. I also
tried to search here without success.
When I deploy my rap.war ( zip auf WEB-INF) in tomcat and start it under
http://localhost:8080/rap/rap. The following error occurs:
The requested resource (BridgeServlet: /rap/rap) is not available.
The deployment auf the rapdemo.war works fine.
The tomcat log-file says quit a lot, but I don't find the reason for my
problem:
!SESSION 2008-11-17 10:52:27.503
eclipse.buildId=unknown
java.version=1.6.0_07
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -console
!ENTRY org.eclipse.equinox.http.servletbridge 4 0 2008-11-17 10:52:27.503
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved.
Reason: Missing Constraint: Import-Package:
org.eclipse.equinox.servletbridge; version="1.0.0"
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:305)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:355)
at
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1074)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:616)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:508)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:299)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:489)
at
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:211)
at
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:321)
!ENTRY org.eclipse.rap.demo 4 0 2008-11-17 10:52:27.534
!MESSAGE
!STACK 0
Reason: Missing Constraint: Require-Bundle: org.eclipse.rap.ui;
bundle-version="0.0.0"
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.rap.ui.workbench 4 0 2008-11-17 10:52:27.550
!MESSAGE
!STACK 0
org.eclipse.rap.jface.databinding; bundle-version="[1.1.0,2.0.0)"
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.rap.ui 4 0 2008-11-17 10:52:27.550
!MESSAGE
!STACK 0
Reason: Missing Constraint: Require-Bundle: org.eclipse.rap.ui.workbench;
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.equinox.http.servletbridge 4 0 2008-11-17 10:52:28.081
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The activator
org.eclipse.equinox.http.servletbridge.internal.Activator for bundle
org.eclipse.equinox.http.servletbridge is invalid
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:146)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:980)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
at
at
at
org.eclipse.osgi.framework.internal.core.PackageAdminImpl.re sumeBundles(PackageAdminImpl.java:272)
at
org.eclipse.osgi.framework.internal.core.PackageAdminImpl.pr ocessDelta(PackageAdminImpl.java:506)
at
org.eclipse.osgi.framework.internal.core.PackageAdminImpl.do ResolveBundles(PackageAdminImpl.java:224)
at
org.eclipse.osgi.framework.internal.core.PackageAdminImpl$1. run(PackageAdminImpl.java:162)
Caused by: java.lang.VerifyError: (class:
org/eclipse/equinox/http/servletbridge/internal/Activator, method: stop
signature: (Lorg/osgi/framework/BundleContext;)V) Incompatible argument to
function
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getConstructor0(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
... 9 more
Root exception:
function
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.osgi 4 0 2008-11-17 10:52:28.112
!MESSAGE Bundle
initial@reference :file:plugins/org.eclipse.equinox.http.servletbridge_1.0.0.2 00811171047.jar/
[10] is not active.
!MESSAGE Bundle
initial@reference:file:plugins/org.eclipse.rap.demo_1.1.1.20080917-1625.jar/
was not resolved.
!MESSAGE Bundle
initial@reference :file:plugins/org.eclipse.rap.ui.workbench_1.1.1.20080917-16 25.jar/
was not resolved.
!MESSAGE Bundle
initial@reference:file:plugins/org.eclipse.rap.ui_1.1.1.20080917-1625.jar/
was not resolved.
I really would appreciate some help
May
FUDForum. Page generated in 0.05588 seconds
