Home » Modeling » M2T (model-to-text transformation) » Difference between eSuperTypes and eAllSuperTypes(usage and difference between eSuperTypes and eAllSuperTypes)
Difference between eSuperTypes and eAllSuperTypes [message #1110482] Mon, 16 September 2013 20:08 Go to next message
Hi all,
i have unclarity about the usage of the Ecore functions.
To get the superclasses of a class, i can use eSuperTypes or eAllSuperTypes. Do you know, what is the difference between them?
I found only these (http://download.eclipse.org/modeling/emf/emf/javadoc/2.9.0/org/eclipse/emf/ecore/EClass.html), (http://help.eclipse.org/indigo/topic/org.eclipse.acceleo.doc/doc/html/ocl_operation_reference.html).
Many thanks,
Daniel
Re: Difference between eSuperTypes and eAllSuperTypes [message #1110561 is a reply to message #1110482] Mon, 16 September 2013 23:13 Go to previous messageGo to next message
Daniel,
Questions about Ecore are best asked on the EMF newsgroup (which I have
copied in this reply).
The eSuperTypes is the list of direct general EClasses. The
eAllSuperTypes list is the closure of all ancestor types: it is
recursively the supertypes, supertypes of those supertypes, etc.
HTH,
Christian
On 2013-09-17 00:08:15 +0000, Daniel Tahin said:
> Hi all,
> I found only these
> Many thanks,
> Daniel
Re: Difference between eSuperTypes and eAllSuperTypes [message #1111206 is a reply to message #1110561] Tue, 17 September 2013 19:56 Go to previous message
Thanks. I got the same result, becuase i had a hierarchy with only 2 levels Smile
Christian W. Damus wrote on Mon, 16 September 2013 23:13
Daniel,
HTH,
Christian
> Hi all,
> I found only these
> Many thanks,
> Daniel
Previous Topic:Debugging during code generation
Next Topic:[Acceleo] NullPointer when executing junit test from maven
Current Time: Tue Nov 04 17:25:08 EST 2025
Powered by FUDForum. Page generated in 0.03609 seconds
