Re: Command Line processing of hprof [message #1069290 is a reply to message #1068232] |
Mon, 15 July 2013 15:54 |
Andrew Johnson Messages: 205 Registered: July 2009 |
Running your query gives output as follows:
class sun.nio.cs.StandardCharsets @ 0x77cb7a4a0,304,8200,0.03488,
class java.util.Locale @ 0x77cbff7e8,232,6968,0.02964,
"java.lang.String @ 0x77cb92bd8 \u0000\u0001\u0002\u0003\u0004\u0005\u0006\u0007\u0008\u0009\u000a\u000b\u000c\u000d\u000e\u000f\u0010\u0011\u0012\u0013\u0014\u0015\u0016\u0017\u0018\u0019\u001a\u001b\u001c\u001d\u001e\u001f !""#$%&'()*+,-./0123456789:;<=>?@ABCDEFGHIJKLMNOPQRSTUVWXYZ[\]^_...",40,2416,0.01028,
class sun.jkernel.DownloadManager @ 0x77cb42bf8,328,2296,0.00977,
Can you parse fields with double quotes around (and commas or doubled double-quotes inside) ?
Do you want to open a bug for the trailing comma or CR instead of CR LF to end each line?
FUDForum. Page generated in 0.05971 seconds
