Home » Eclipse Projects » Gemini » ATTN: Gemini Management subproject about to be shut down!
Re: ATTN: Gemini Management subproject about to be shut down! [message #1084988 is a reply to message #1078107] |
Mon, 12 August 2013 09:45 |
To anyone thinking about stepping up, the time required is even less than Mike has suggested. The project simply provides an implementation of the OSGi enterprise JMX spec. There should be no major work required unless the spec changes or you feel like improving the test coverage. The code base isn't very big and no bugs have been raised in quite some time. I'm not disappearing off the internet and I'm more than happy to provide any help wanted to someone stepping up.
Thanks, Chris.
Chris Frost, Twitter @cgfrost
Springsource, a divison of VMware.
Re: ATTN: Gemini Management subproject about to be shut down! [message #1112197 is a reply to message #1111809] |
Thu, 19 September 2013 08:38 |
Fear not, Florian Waibel from Eclispe source has stepped up to take on the leadership of Gemini Management. The paperwork is in progress at the moment. We are still looking for someone to take on Virgo, if you or your company are using Virgo why not see if a little extra commitment to the project would be acceptable and step up to take the lead.
Chris.
Re: ATTN: Gemini Management subproject about to be shut down! [message #1112931 is a reply to message #1112843] |
Fri, 20 September 2013 11:33 |
Eduardo Frazão Messages: 123 Registered: January 2012 |
Hi Chris!
I'm working on a project of a production automation system. We are developing Hardware and Software.
The management software is a Web product, and is directed to administrative tasks, including, setup of the automation production parameters of products. In true, each product of each company can use several equipments to be produced, like mixers, liquid valves, etc. Eeach hardware haves its own ways to operate. So, for each hardware parameters implementation, I have a small specialist bundle, that provide services for the web application. Latter, this parameters and production orders is delivered to a desktop application that do the hard work .
This management application runs with Virgo Tomcat and Vaadin.
The desktop application:
To control the hardware, we have another application, a desktop one, that runs with JavaFX 2 and Virgo Kernel, that effectivelly manage the production sending commands to our hardware that manages the eletric and eletronic stuff. Each device protocol is implemented as bundles, because each customer and their factorys have different ones.
And it's not only it. We have bundles to integrate to other systems, or to do customer specific tasks, without changing the general core, etc.
It will be mutch harder to develop this, without OSGi!
Current Time: Wed Jan 15 05:27:01 GMT 2025
Powered by FUDForum. Page generated in 0.27523 seconds
