Home » Eclipse Projects » Rich Client Platform (RCP) » Is it possible to name two classes in a command handler?
Is it possible to name two classes in a command handler? [message #1083104] Fri, 09 August 2013 09:28 Go to next message
I just started a new company/project that is moving from Swing to RCP/SWT. I'm reviewing some of the code changes they've started making and noticed this interesting tidbit:
<handler
class="xxx.WrappedActionDelegatingHandler:xxx.MyCreateAction"
commandId="xxx.myCommandId">
I've run the application and both classes are indeed called. I haven't delved too deeply into how they are both called but I've never seen this done before.
Is it expected behaviour that both classes are called? I can't find any RCP documentation on this behaviour. Or is the application I'm looking at done something nonstandard somewhere else in the code? (This is a very large, multi-tiered application. Digging through the guts is currently difficult.)
Re: Is it possible to name two classes in a command handler? [message #1088094 is a reply to message #1083104] Fri, 16 August 2013 11:14 Go to previous message
Hi Chris,
This is how to pass a command parameter. I guess in the "guts" there is a call to that specific class.
http://wiki.eclipse.org/Platform_Command_Framework#Executing_a_command_with_parameters
Wim
Previous Topic:Calling RCP Application from a eclipse plugin
Next Topic:Is it possible to have tabs on top and on bottom to switch views?
Current Time: Wed Apr 16 06:47:43 EDT 2025
Powered by FUDForum. Page generated in 0.04967 seconds
