| Unable to build project (java.lang.NullPointerException) [message #1083091] |
Fri, 09 August 2013 09:03  |
It's been a while since I've needed to work on a C++ project, but recently I've been trying to get back into it, by installing CDT. Now I'm not even getting the example Hello World project compiled, and I'm starting to suspect a bug rather than wrong settings.
My environment:
- Fedora 19, 64bit, kernel 3.10.4-300
- g++ (GCC) 4.8.1, GNU Make 3.82, GNU gdb (GDB) Fedora (7.6-32.fc19)
- Eclipse Kepler (manually installed)
- CDT 8.2
- Oracle Java 1.7.0_25
The problem:
I create a new C++ project, with the HelloWorld template. I chose the Linux GCC toolchain. The project is created, but no 'Binary' folder shows up. Only the 'src' folder. Also, in the Project Properties > C/C++ General > Paths and Symbols > Inludes, no includes or symbols show up (I thought this was supposed to work automatically).
So, initially, "#include <iostream>" and "cout" and "endl" show up as errors.
I can manually add the includes to Paths and Symbols to solve this.
Now, clicking the "Build Project" button, gives me this dialog:
Errors occurred during the build.
Errors running builder 'CDT Builder' on project 'HelloWorldCPP'.
Internal error building project HelloWorldCPP configuration Debug
And that's that.
Creating the project in a new workspace doesn't change a thing.
Would this be a CDT bug? Or something wrong with my setup or settings?
Thanks!
| Re: Unable to build project (java.lang.NullPointerException) [message #1403362 is a reply to message #1083091] |
Wed, 23 July 2014 04:32  |
Actually I have this problem too.I imported a cocos2d-x project and it worked fine but i just restart eclipse and then this errors shows up.
I'm using these:
ADT Package 23.0.2.1259578
CDT 8.0.2.201202111925
and this is log:
eclipse.buildId=M20130204-1200
java.version=1.8.0_05
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product com.android.ide.eclipse.adt.package.adtproduct
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product com.android.ide.eclipse.adt.package.adtproduct
!ENTRY com.android.ide.eclipse.adt 4 0 2014-07-23 12:39:39.892
!MESSAGE
!STACK 1
org.eclipse.core.internal.resources.ResourceException: Resource '/mydamngame/res' does not exist.
at org.eclipse.core.internal.resources.Resource.checkExists(Resource.java:341)
at org.eclipse.core.internal.resources.Resource.checkAccessible(Resource.java:215)
at org.eclipse.core.internal.resources.Container.members(Container.java:266)
at org.eclipse.core.internal.resources.Container.members(Container.java:249)
at com.android.ide.eclipse.adt.internal.sdk.Sdk$7.run(Sdk.java:1485)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
!SUBENTRY 1 org.eclipse.core.resources 4 368 2014-07-23 12:39:39.894
!MESSAGE Resource '/mydamngame/res' does not exist.
!ENTRY org.eclipse.egit.ui 2 0 2014-07-23 12:39:40.309
!MESSAGE Warning: EGit couldn't detect the installation path "gitPrefix" of native Git. Hence EGit can't respect system level
Git settings which might be configured in ${gitPrefix}/etc/gitconfig under the native Git installation directory.
The most important of these settings is core.autocrlf. Git for Windows by default sets this parameter to true in
this system level configuration. The Git installation location can be configured on the
Team > Git > Configuration preference page's 'System Settings' tab.
This warning can be switched off on the Team > Git > Confirmations and Warnings preference page.
!ENTRY org.eclipse.egit.ui 2 0 2014-07-23 12:39:40.313
!MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git
user global configuration and to define the default location to store repositories: 'C:\Users\ABBAS-PC'. If this is
not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and
EGit might behave differently since they see different configuration options.
!ENTRY org.eclipse.cdt.core 4 0 2014-07-23 12:39:44.477
!MESSAGE Error
!STACK 0
at org.eclipse.cdt.internal.core.settings.model.CConfigurationDescriptionCache.loadData(CConfigurationDescriptionCache.java:104)
at org.eclipse.cdt.internal.core.settings.model.CProjectDescription.loadDatas(CProjectDescription.java:196)
at org.eclipse.cdt.internal.core.settings.model.xml.XmlProjectDescriptionStorage.loadProjectDescription(XmlProjectDescriptionStorage.java:486)
at org.eclipse.cdt.internal.core.settings.model.xml.XmlProjectDescriptionStorage.getProjectDescription(XmlProjectDescriptionStorage.java:231)
at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.getProjectDescriptionInternal(CProjectDescriptionManager.java:416)
at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.getProjectDescription(CProjectDescriptionManager.java:398)
at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.getProjectDescription(CProjectDescriptionManager.java:393)
at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.getProjectDescription(CProjectDescriptionManager.java:386)
at org.eclipse.cdt.core.model.CoreModel.getProjectDescription(CoreModel.java:1423)
at org.eclipse.cdt.internal.core.index.IndexFactory.safeAddProvidedFragments(IndexFactory.java:210)
at org.eclipse.cdt.internal.core.index.IndexFactory.getWritableIndex(IndexFactory.java:106)
at org.eclipse.cdt.internal.core.pdom.PDOMManager.getWritableIndex(PDOMManager.java:1173)
at org.eclipse.cdt.internal.core.pdom.indexer.PDOMRebuildTask.run(PDOMRebuildTask.java:69)
at org.eclipse.cdt.internal.core.pdom.PDOMIndexerJob.run(PDOMIndexerJob.java:137)
!ENTRY org.eclipse.core.jobs 4 2 2014-07-23 12:39:44.485
!MESSAGE An internal error occurred during: "C/C++ Indexer".
!STACK 0
!ENTRY org.eclipse.cdt.core 4 0 2014-07-23 12:39:45.426
!MESSAGE Error
!STACK 0
at org.eclipse.cdt.internal.core.model.CProject.computeSourceRoots(CProject.java:603)
at org.eclipse.cdt.internal.core.model.CProject.computeChildren(CProject.java:624)
at org.eclipse.cdt.internal.core.model.CProject.buildStructure(CProject.java:588)
at org.eclipse.cdt.internal.core.model.Openable.generateInfos(Openable.java:265)
at org.eclipse.cdt.internal.core.model.CElement.openWhenClosed(CElement.java:428)
at org.eclipse.cdt.internal.core.model.CElement.getElementInfo(CElement.java:307)
at org.eclipse.cdt.internal.core.model.CElement.getElementInfo(CElement.java:297)
at org.eclipse.cdt.internal.core.model.Parent.getChildren(Parent.java:55)
at org.eclipse.cdt.internal.core.model.CProject.getSourceRoots(CProject.java:480)
at org.eclipse.cdt.internal.core.model.CModelManager.create(CModelManager.java:327)
at org.eclipse.cdt.internal.core.model.CModelManager.create(CModelManager.java:255)
at org.eclipse.cdt.internal.core.model.DeltaProcessor.createElement(DeltaProcessor.java:88)
at org.eclipse.cdt.internal.core.model.DeltaProcessor.traverseDelta(DeltaProcessor.java:454)
at org.eclipse.cdt.internal.core.model.DeltaProcessor.traverseDelta(DeltaProcessor.java:472)
at org.eclipse.cdt.internal.core.model.DeltaProcessor.processResourceDelta(DeltaProcessor.java:434)
at org.eclipse.cdt.internal.core.model.CModelManager.resourceChanged(CModelManager.java:886)
at org.eclipse.core.internal.events.NotificationManager$1.run(NotificationManager.java:291)
at org.eclipse.core.internal.events.NotificationManager.notify(NotificationManager.java:285)
at org.eclipse.core.internal.events.NotificationManager.broadcastChanges(NotificationManager.java:149)
at org.eclipse.core.internal.resources.Workspace.broadcastPostChange(Workspace.java:395)
at org.eclipse.core.internal.resources.Workspace.endOperation(Workspace.java:1530)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2353)
at org.eclipse.core.internal.events.NotificationManager$NotifyJob.run(NotificationManager.java:40)
!ENTRY org.eclipse.cdt.core 4 0 2014-07-23 12:39:50.886
!MESSAGE Error
!STACK 0
at org.eclipse.cdt.internal.core.model.CModelManager.create(CModelManager.java:280)
at org.eclipse.cdt.internal.core.model.CModelManager.create(CModelManager.java:257)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:156)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
!ENTRY org.eclipse.ui 2 2 2014-07-23 12:44:25.128
!MESSAGE Invalid property category path: ValidationPropertiesPage (bundle: org.eclipse.wst.xml.ui, propertyPage: org.eclipse.wst.xml.ui.propertyPage.project.validation)
!ENTRY org.eclipse.cdt.core 4 0 2014-07-23 12:44:25.451
!MESSAGE Error
!STACK 0
FUDForum. Page generated in 0.04642 seconds
