Home » Archived » M2M (model-to-model transformation) » [ATL] Running ATL Transformation from JAVA
[ATL] Running ATL Transformation from JAVA [message #106812] Thu, 18 June 2009 10:30 Go to next message
I am in the process of writing an application, which after compiling an
ATL file, will then run the transformation.
I had some difficulties, since some of the examples available in the "ATL
How to" web page seem to be out-of-date. In particular, I had some
difficulties with the model handlers.
Attached is the code that I managed to put together after looking at other
examples, however, I get errors when trying to run the transformation.
Here is my code:
package org.ATLCodeGenerator.test1;
import java.io.IOException;
import java.net.URL;
import java.util.Collections;
import java.util.HashMap;
import java.util.Map;
import org.eclipse.emf.common.util.URI;
import org.eclipse.gmt.tcs.injector.ASMModelHandler;
import org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel;
import org.eclipse.m2m.atl.drivers.emf4atl.AtlEMFModelHandler;
import org.eclipse.m2m.atl.drivers.emf4atl.EMFModelLoader;
import org.eclipse.m2m.atl.engine.vm.*;
import org.eclipse.m2m.atl.engine.vm.nativelib.ASMModel;
class ATLTransformation {
private static ATLTransformation instance = null;
private final static String resourcePath =
"C:/Users/Miguel/Documents/TESE - FCT/ATL/ATL Code Generation/Metamodels";
private AtlEMFModelHandler modelHandler;
private EMFModelLoader ml;
private URI FootwearResource;
private URI ShoesResource;
private ASMEMFModel footMetamodel;
private ASMEMFModel shoesMetamodel;
private URL Footwear2Shoes_TransfoResource;
static public ATLTransformation getInstance() {
if (instance == null)
instance = new ATLTransformation();
return instance;
private void createResources() {
//modelHandler = AtlModelHandler.getDefault("EMF");
FootwearResource = URI.createPlatformPluginURI(resourcePath +
"Footwear.ecore", false);
ShoesResource = URI.createPlatformPluginURI(resourcePath +
"Shoes.ecore", false);
Footwear2Shoes_TransfoResource =
ATLTransformation.class.getResource("Footwear2Shoes.asm");
private void initMetamodels(Map<String, Object> models) throws
IOException {
AtlModelHandler emfamh =
AtlModelHandler.getDefault(AtlModelHandler.AMH_EMF);
ml = (EMFModelLoader) emfamh.createModelLoader();
footMetamodel = (ASMEMFModel) ml.loadModel("Footwear", ml.getMOF(),
FootwearResource);
models.put("Footwear", footMetamodel);
public void foot2shoes(String inFilePath, String outFilePath) {
try {
Map<String, Object> models = new HashMap<String, Object>();
createResources();
initMetamodels(models);
// get/create models
ASMEMFModel footInputModel = (ASMEMFModel) ml.loadModel("IN",
footMetamodel, URI.createFileURI(inFilePath));
ASMEMFModel shoesOutputModel = (ASMEMFModel) ml.newModel("OUT",
URI.createFileURI(outFilePath).toFileString(), shoesMetamodel);
// load models
models.put("IN", footInputModel);
models.put("OUT", shoesOutputModel);
// launch
AtlLauncher.getDefault().launch(this.JWT2BPMN_Pool_TransfoRe source,
Collections.EMPTY_MAP, models, Collections.EMPTY_MAP,
Collections.EMPTY_LIST, Collections.EMPTY_MAP);
ml.save(shoesOutputModel, outFilePath);
//dispose(models);
} catch (Exception e) {
e.printStackTrace();
These are the errors that I am getting after calling the transformation
from the main method:
Exception in thread "main" java.lang.SecurityException: class
"org.eclipse.core.runtime.IStatus"'s signer information does not match
signer information of other classes in the same package
at java.lang.ClassLoader.checkCerts(Unknown Source)
at java.lang.ClassLoader.preDefineClass(Unknown Source)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$000(Unknown Source)
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at
org.eclipse.m2m.atl.engine.compiler.AtlDefaultCompiler.inter nalCompile(AtlDefaultCompiler.java:204)
at
org.eclipse.m2m.atl.engine.compiler.AtlDefaultCompiler.compi le(AtlDefaultCompiler.java:64)
at
org.ATLCodeGenerator.test1.ATLCodeGenerator.main(ATLCodeGene rator.java:56)
Any help would be greatly appreciated.
Thank you,
Miguel Beça
Re: [ATL] Running ATL Transformation from JAVA [message #106848 is a reply to message #106812] Fri, 19 June 2009 07:36 Go to previous messageGo to next message
Using the latest ATL version (3.0.x), you can refer to this
doccumentation: http://wiki.eclipse.org/ATL/Developer_Guide#Examples_of_use
William
Miguel Beca a écrit :
> Hello,
> "ATL How to" web page seem to be out-of-date. In particular, I had some
> other examples, however, I get errors when trying to run the
> transformation.
> Here is my code:
> return instance;
> IOException {
> ml.getMOF(), FootwearResource);
> try {
> Object>();
> createResources();
> ml.loadModel("IN", footMetamodel, URI.createFileURI(inFilePath));
> ml.newModel("OUT", URI.createFileURI(outFilePath).toFileString(),
> shoesMetamodel);
> // load models
> // launch
> //dispose(models);
> at java.security.AccessController.doPrivileged(Native Method)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> Thank you,
> Miguel Beça
Re: [ATL] Running ATL Transformation from JAVA [message #106977 is a reply to message #106848] Fri, 19 June 2009 15:53 Go to previous messageGo to next message
Dear William,
Thank you for your suggestion.
I tried using the PrivatizeAction.java example and adapted it to my case.
However, I am now getting this error:
org.eclipse.m2m.atl.core.ATLCoreException:
org.eclipse.m2m.atl.core.injector EMF not found, check the spelling or
register it manually.
My code is below. Any help is appreciated.
Miguel
import java.util.Iterator;
import org.eclipse.core.resources.IFile;
import org.eclipse.core.resources.IProject;
import org.eclipse.core.runtime.NullProgressMonitor;
import org.eclipse.core.runtime.Platform;
import org.eclipse.m2m.atl.core.ATLCoreException;
import org.eclipse.m2m.atl.core.IExtractor;
import org.eclipse.m2m.atl.core.IInjector;
import org.eclipse.m2m.atl.core.IModel;
import org.eclipse.m2m.atl.core.IReferenceModel;
import org.eclipse.m2m.atl.core.ModelFactory;
import org.eclipse.m2m.atl.core.launch.ILauncher;
import org.eclipse.m2m.atl.core.service.CoreService;
import org.osgi.framework.Bundle;
public class ATLTransformationLauncher {
private static IInjector injector;
private static IExtractor extractor;
private static IReferenceModel umlMetamodel;
private static IReferenceModel refiningTraceMetamodel;
private static IReferenceModel footMetamodel;
private static IReferenceModel shoesMetamodel;
private static URL asmURL;
static {
try {
asmURL = new URL("Footwear2Shoes.asm");
// TODO: handle exception
try {
injector = CoreService.getInjector("EMF"); //$NON-NLS-1$
extractor = CoreService.getExtractor("EMF"); //$NON-NLS-1$
} catch (ATLCoreException e) {
* Constructor for Action1.
public ATLTransformationLauncher(){
super();
public void Foot2ShoesLaunch(IFile file) throws Exception {
// Defaults
ModelFactory factory = CoreService.createModelFactory("EMF");
//$NON-NLS-1$
// Metamodels
footMetamodel = factory.newReferenceModel();
injector.inject(footMetamodel,
" file:/C:/Users/Miguel/workspace/ATLTransformationGenerator/m etamodels/Footwear.ecore ");
//$NON-NLS-1$
shoesMetamodel =
factory.getBuiltInResource(" file:/C:/Users/Miguel/workspace/ATLTransformationGenerator/m etamodels/Shoes.ecore ");
//$NON-NLS-1$
// Getting launcher
ILauncher launcher = null;
launcher = CoreService.getLauncher("EMF-specific VM"); //$NON-NLS-1$
launcher.initialize(Collections.<String, Object> emptyMap());
// Creating models
IModel shoesModel = factory.newModel(shoesMetamodel);
IModel footModel = factory.newModel(footMetamodel);
// Loading existing model
injector.inject(footModel, file.getFullPath().toString());
// Launching
launcher.addOutModel(shoesModel, "shoes", "Shoes"); //$NON-NLS-1$
//$NON-NLS-2$
launcher.addInModel(footModel, "foot", "Footwear"); //$NON-NLS-1$
//$NON-NLS-2$
launcher.launch(ILauncher.RUN_MODE, new NullProgressMonitor(),
Collections
.<String, Object> emptyMap(), asmURL.openStream());
// Saving model
extractor.extract(shoesModel, file.getFullPath().toString());
// Refresh workspace
file.getParent().refreshLocal(IProject.DEPTH_INFINITE, null);
Re: [ATL] Running ATL Transformation from JAVA [message #107056 is a reply to message #106977] Wed, 24 June 2009 13:53 Go to previous messageGo to next message
Could you please explain how do you launch your project ?
e.g. :
- Eclipse with EMF and ATL installed
- a workspace containing your project
- a runtime where you launch the transformation (e.g. with a popup)
Or something else ?
The CoreService uses Eclipse's extension points to retrieve injectors,
extractors etc..
To work out of Eclipse you have to manually register injectors and
extractors (see CoreService.registerInjector(String name, IInjector
injector) for example).
William
> Dear William,
> case. However, I am now getting this error:
> Miguel
> static {
> try {
> try {
> //$NON-NLS-1$
> super();
> // Defaults
> //$NON-NLS-1$
> // Metamodels
> //$NON-NLS-1$
> shoesMetamodel =
> //$NON-NLS-1$
> // Getting launcher
> //$NON-NLS-1$
> // Creating models
> // Launching
> //$NON-NLS-1$ //$NON-NLS-2$
> Collections
> // Saving model
Re: [ATL] Running ATL Transformation from JAVA [message #107071 is a reply to message #107056] Wed, 24 June 2009 14:09 Go to previous messageGo to next message
Hi William,
Thank you for your help.
I am writing an application in Eclipse and using EMF and ATL. The final
objective is to write a program that will both compile an ATL file and the
execute the compiled .asm file.
Is this sufficient information for you?
Miguel
William Piers wrote:
> e.g. :
> Or something else ?
> extractors etc..
> William
>> Dear William,
>> Thanks,
>> Miguel
>> static {
>> try {
>> try {
>> //$NON-NLS-1$
>> super();
>> // Defaults
>> //$NON-NLS-1$
>> // Metamodels
>> //$NON-NLS-1$
>> shoesMetamodel =
>> //$NON-NLS-1$
>> // Getting launcher
>> //$NON-NLS-1$
>> // Creating models
>> // Launching
>> Collections
>> // Saving model
Re: [ATL] Running ATL Transformation from JAVA [message #108273 is a reply to message #106977] Sat, 11 July 2009 19:58 Go to previous message
Hello Miguel,
I'm also on a quest to invoke ATL from Java. Where did you import
org.eclipse.gmt.tcs.injector and
org.eclipse.core.runtime.NullProgressMonitor from? I can't seem to find
any packages that has them! org.eclipse.core.runtime_3.4.0.v20080512.jar
does not seem to have NullProgressMonitor!
Thanks in advance,
Panto
Miguel Beca wrote:
> Dear William,
> Miguel
> static {
> try {
> try {
> //$NON-NLS-1$
> super();
> // Defaults
> //$NON-NLS-1$
> // Metamodels
> //$NON-NLS-1$
> shoesMetamodel =
> //$NON-NLS-1$
> // Getting launcher
> //$NON-NLS-1$
> // Creating models
> // Launching
> Collections
> // Saving model
Previous Topic:How to duplicate an element
Next Topic:add an element to a sequence
Current Time: Mon Feb 10 22:29:26 GMT 2025
Powered by FUDForum. Page generated in 0.04375 seconds
