Home » Archived » M2M (model-to-model transformation) » [ATL] Problems with allInstancesFrom()
[ATL] Problems with allInstancesFrom() [message #107822] Sat, 04 July 2009 08:59 Go to next message
Originally posted by: mschneider.uni-koblenz.de
Hello everyone,
I'm kinda new to ATL so please bear with me, if it's a simple problem :)
I'm currently running ATL 2.0.2 and encountered this problem.
My input model is UML and I'm trying to gather all UML!Generalization
for further transformation. Since I need to do so twice I use the
following code with 2 different rules and for testing issues print out
all specific classes:
UML!Generalization.allInstancesFrom('IN')->collect(e|e.specific).toString();
The problem, from the first rule I get 2 specific classes, from the
second rule none.
How is this even possible? Because I thought ATL is only transforming
the input model and not also editing or removing parts of it.
Any kind of help will be highly appreciated.
With kind regards,
Mark Schneider
Re: [ATL] Problems with allInstancesFrom() [message #108086 is a reply to message #107822] Wed, 08 July 2009 15:54 Go to previous messageGo to next message
Hi again,
I'm still pretty stuck. Really no one has any idea?
Thanks for any help.
Mark
Mark Schneider schrieb:
> Hello everyone,
> second rule none.
> With kind regards,
> Mark Schneider
Re: [ATL] Problems with allInstancesFrom() [message #108475 is a reply to message #108086] Mon, 20 July 2009 04:59 Go to previous messageGo to next message
Could you please try to test the same transformation using the latest
ATL version (3.0.0) ?
Thanks in advance,
William
Mark Schneider a écrit :
> Hi again,
> Regards,
> Mark
>> Hello everyone,
>> second rule none.
>> With kind regards,
>> Mark Schneider
Re: [ATL] Problems with allInstancesFrom() [message #108604 is a reply to message #108475] Thu, 23 July 2009 06:38 Go to previous message
Hello William,
since there was no help for quite a while I managed to work around that
problem regarding my transformation. Nevertheless I was curious if the
problem still remains in ATL 3.0.0 and I can gladly tell, that it got
solved with the version upgrade. Thanks anyway for your help!
Mark
William Piers schrieb:
> Hello,
> Thanks in advance,
> William
>> Hi again,
>> Regards,
>> Mark
>>> Hello everyone,
>>> out all specific classes:
>>> second rule none.
>>> With kind regards,
>>> Mark Schneider
Previous Topic:[ATL] stack overflow from simple script
Next Topic:[ATL]org.eclipse.emf.ecore.xmi.PackageNotFoundException:
Current Time: Sun Oct 26 03:45:14 EDT 2025
Powered by FUDForum. Page generated in 0.03645 seconds
