Home » Eclipse Projects » Gemini » Start Gemini-web-test failed,can't find rt.jar
Start Gemini-web-test failed,can't find rt.jar [message #1061977] Wed, 05 June 2013 08:36 Go to next message
Roy Song is currently offline Roy SongFriend
Hello,guys!
I followed Gemini-web's userguide step by step,when I step on:
java -jar org.eclipse.osgi_3.8.2.v20130124-134944.jar -console
I got following exceptions:
Failed to trigger creation of the GC Daemon thread during Tomcat start to
prevent possible memory leaks. This is expected on non-Sun JVMs.
java.lang.ClassNotFoundException: sun.misc.GC
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(Bundl
eLoader.java:501)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.
java:421)
java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(De
faultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:171)
at org.apache.catalina.core.JreMemoryLeakPreventionListener.lifecycleEve
nt(JreMemoryLeakPreventionListener.java:295)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(Lifecycl
eSupport.java:119)
at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBa
se.java:90)
at org.apache.catalina.util.LifecycleBase.setStateInternal(LifecycleBase
.java:402)
at org.apache.catalina.util.LifecycleBase.init(LifecycleBase.java:99)
at org.eclipse.gemini.web.tomcat.internal.OsgiAwareEmbeddedTomcat.init(O
sgiAwareEmbeddedTomcat.java:197)
at org.eclipse.gemini.web.tomcat.internal.TomcatServletContainer.<init>(
TomcatServletContainer.java:62)
at org.eclipse.gemini.web.tomcat.internal.TomcatServletContainerFactory.
createContainer(TomcatServletContainerFactory.java:29)
at org.eclipse.gemini.web.tomcat.internal.Activator.createContainer(Acti
vator.java:107)
at org.eclipse.gemini.web.tomcat.internal.Activator.start(Activator.java
:58)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(Bund
leContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActiv
ator(BundleContextImpl.java:702)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(Bund
leContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(Bundl
eHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(Abstra
ctBundle.java:390)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Frame
work.java:1176)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBund
les(StartLevelManager.java:559)
les(StartLevelManager.java:544)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(St
artLevelManager.java:457)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStart
Level(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEv
ent(StartLevelManager.java:438)
ent(StartLevelManager.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventM
anager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(Even
tManager.java:340)
2013-6-5 15:53:36 org.apache.catalina.core.JreMemoryLeakPreventionListener lifec
ycleEvent
Failed to trigger creation of the com.sun.jndi.ldap.LdapPoolManager class
during Tomcat start to prevent possible memory leaks. This is expected on non-Su
n JVMs.
java.lang.ClassNotFoundException: com.sun.jndi.ldap.LdapPoolManager
eLoader.java:501)
java:421)
java:412)
nt(JreMemoryLeakPreventionListener.java:432)
eSupport.java:119)
se.java:90)
.java:402)
vator.java:107)
:58)
eHost.java:381)
ctBundle.java:390)
work.java:1176)
anager.java:230)
tManager.java:340)
My system is win7(64),and my JAVA_HOME is C:\Program Files\Java\jdk1.6.0_45.I found these not found classes in JRE\lib\rt.jar;but I don't understand why they can't be loaded.
I used google and stackoverflow to find answer ,but nothing found.So,I got here and hoped some help.
Maybe I used wrong version of osgi jar?I can't confirm it.
Thanks for helping and apologize for my poor English.
Re: Start Gemini-web-test failed,can't find rt.jar [message #1062076 is a reply to message #1061977] Wed, 05 June 2013 18:19 Go to previous messageGo to next message
Violeta Georgieva is currently offline Violeta GeorgievaFriend
Do you have running console after this exception?
If yes please execute command "getprop" and post the result here.
Violeta
Re: Start Gemini-web-test failed,can't find rt.jar [message #1062116 is a reply to message #1062076] Thu, 06 June 2013 06:01 Go to previous messageGo to next message
Thanks for reply,Violeta.
After exception,I always close it and rerun,and got the same exception.
I put "getprop" infos in attachment "getprop.txt".I really don't know how to fix it.
Thanks for help again.
  • Attachment: getprop.txt
    (Size: 12.09KB, Downloaded 1349 times)
Re: Start Gemini-web-test failed,can't find rt.jar [message #1077914 is a reply to message #1062116] Fri, 02 August 2013 09:58 Go to previous messageGo to next message
sun wang is currently offline sun wangFriend
me too,the same as roy song.
my english is very poor.
thank you Smile
Re: Start Gemini-web-test failed,can't find rt.jar [message #1392782 is a reply to message #1077914] Wed, 02 July 2014 21:14 Go to previous messageGo to next message
Julio Rey is currently offline Julio ReyFriend
Hi everyone, i have the same problem
Roy do you can solve this issue?
Is necessary someone JAR to get the classes
com.sun.jndi.ldap .LdapPoolManager
sun.misc .GC
i do all steps of
/gemini/web/documentation/gemini-web-documentation-2.2.3.RELEASE/gemini-web-user-guide/html/ch02s02.html
Thanks a lot,
this is my exception
Advertencia: Couldn't initialize Jasper
java.lang.ClassNotFoundException: org .apache. jasper.compiler. JspRuntimeContext cannot be found by java.lang.ClassNotFoundException: sun.misc.GC cannot be found by java.lang.ClassNotFoundException: com.sun.jndi.ldap. LdapPoolManager cannot be found by org.apache.catalina_7.0.53.v201406061610
Re: Start Gemini-web-test failed,can't find rt.jar [message #1394340 is a reply to message #1392782] Sat, 05 July 2014 05:40 Go to previous message
Use the following to start GW
java -Dosgi.compatibility.bootdelegation=true -jar org.eclipse.osgi.jar -console
if set to "true" then the parent (boot by default) classloader is delegated to as a last resort if a class or resource cannot be found.
Violeta
Previous Topic:[Blueprint] Snapshots are now in eclipse maven repo
Next Topic:Gemini Web 2.2.3 RELEASE is now available
Current Time: Wed Jan 15 06:06:18 GMT 2025
Powered by FUDForum. Page generated in 0.05190 seconds
