Home » Eclipse Projects » EclipseLink » MOXy: Override rules of binding files
MOXy: Override rules of binding files [message #1076962] Thu, 01 August 2013 00:18 Go to next message
I would, in the scenario below, like the binding of java-type name="SubClass" to be applied to set the text field on SuperClass. However it is not. Is there a problem with overriding the bindingsA.xml? According to the Overriding rules:
If the same java-type occurs in multiple files, any values that are set in the later file, will override values from the previous file
What do I need to do to make it work?
Input:
<a text="A text">B text</a>
Bindings A:
<?xml version="1.0"?>
<xml-bindings
 xmlns="http://www.eclipse.org/eclipselink/xsds/persistence/oxm"
 package-name="test">
 <java-types>
   <java-type name="SuperClass">
    <xml-root-element name="a"/>
    <java-attributes>
        <xml-element java-attribute="text" xml-path="@text" />
    </java-attributes>
  </java-type>
 </java-types>
</xml-bindings>
Bindings B:
<?xmlversion="1.0"?>
<xml-bindings
<java-types>
  <java-type name="SuperClass" xml-transient="true"></java-type>
  <java-type name="SubClass">
    <java-attributes>
        <xml-element java-attribute="text" xml-path="text()" />
    </java-attributes>
  </java-type>
</java-types>
</xml-bindings>
Classes:
public class SuperClass {
 private String text;
 public String getText() {
    return text;
 public void setText(String text) {
    this.text = text;
public class SubClass extends SuperClass { }
Demo:
Map<String, Object> jaxbContextProperties = new HashMap<String, Object>(1);
List<String> bindings = new LinkedList<String>();
bindings.add("bindingsA.xml");
bindings.add("bindingsB.xml");
jaxbContextProperties.put(JAXBContextProperties.OXM_METADATA_SOURCE, bindings);
JAXBContext jaxbContext = JAXBContextFactory.createContext(new Class[] {SuperClass.class}, jaxbContextProperties);
Unmarshaller unmarshaller = jaxbContext.createUnmarshaller();
SuperClass superClass = (SuperClass)unmarshaller.unmarshal(new File("input.xml"));
System.out.println(superClass.getText());
Output:
[EL Warning]: 2013-07-31 16:08:07.771--Ignoring attribute [text] on class [SubClass] as no Property was generated for it.
A text
Re: MOXy: Override rules of binding files [message #1077369 is a reply to message #1076962] Thu, 01 August 2013 11:51 Go to previous message
It's a bit odd to map the text property differently on the super and sub classes. If this is something you really want to do, then below is a way you could accomplish this.
Java Model
SuperClass
package forum17982654;
        return text;
        this.text = text;
SubClass
We will override the accessor methods from the super class. This will help us trick MOXy into thinking that SubClass has its own property text.
        return super.getText();
        super.setText(text);
Metadata
bindings.xml
In the mapping document we will tell MOXy that the real super class of SubClass is java.lang.Object.
<xml-bindings
    package-name="forum17982654">
    <java-types>
            <xml-root-element/>
            <java-attributes>
                <xml-attribute java-attribute="text"/>
            </java-attributes>
        </java-type>
        <java-type name="SubClass" super-type="java.lang.Object">
            <xml-root-element/>
            <java-attributes>
                <xml-value java-attribute="text"/>
            </java-attributes>
        </java-type>
    </java-types>
</xml-bindings>
Demo Code
Below is some demo code you can run to prove that everything works:
Demo
import java.io.StringReader;
import java.util.*;
import javax.xml.bind.*;
import org.eclipse.persistence.jaxb.JAXBContextFactory;
import org.eclipse.persistence.jaxb.JAXBContextProperties;
public class Demo {
    public static void main(String[] args) throws Exception {
        jaxbContextProperties.put(JAXBContextProperties.OXM_METADATA_SOURCE, "bindings.xml");
        StringReader superClassXML = new StringReader("<superClass text='Hello Super Class'/>");
        SuperClass superClass = (SuperClass) unmarshaller.unmarshal(superClassXML);
        StringReader subClassXML = new StringReader("<subClass>Hello Sub Class</subClass>");
        SubClass subClass = (SubClass) unmarshaller.unmarshal(subClassXML);
        System.out.println(subClass.getText());
Output
Hello Super Class
Hello Sub Class
Previous Topic:EclipseLink MOXy: Logical operators in XmlPath annotation
Next Topic:MongoDB queries throwing NPE
Current Time: Mon Nov 03 17:36:02 EST 2025
Powered by FUDForum. Page generated in 0.03701 seconds
