Home » Eclipse Projects » Remote Application Platform (RAP) » ProgressMonitor "always run in background" problem
ProgressMonitor "always run in background" problem [message #107461] Wed, 01 October 2008 07:13 Go to next message
during an action I was showing a ProgressMonitor.
Then I checked the Checkbox "always run in background".
But now I never saw the Dialog again and don't know how re-show it.
Can somebody help me???
Roland
Re: ProgressMonitor "always run in background" problem [message #107477 is a reply to message #107461] Wed, 01 October 2008 07:55 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Roland,
did you try what was suggested in this post?
http://dev.eclipse.org/newslists/news.eclipse.technology.rap /msg04266.html
HTH
Rüdiger
Roland Siebert wrote:
> Roland
Re: ProgressMonitor "always run in background" problem [message #107491 is a reply to message #107477] Wed, 01 October 2008 08:05 Go to previous messageGo to next message
Thanks.
Exactly what I'm searching for.
It works.
Roland
Rüdiger Herrmann schrieb:
> Roland,
> HTH
> Rüdiger
>> Hi,
>> Roland
Re: ProgressMonitor "always run in background" problem [message #517024 is a reply to message #107477] Thu, 25 February 2010 14:04 Go to previous messageGo to next message
I recently checked "Always run in background" for the "Progress" view. I would like to undo this. How can this be accomplished?
From your previous post, you point to a thread that states that I would have to edit the Eclipse code to do this? That doesn't make sense to me. At most I would think that I would have to change some persistent setting somewhere. But edit the code?!?!
Thank you.
Re: ProgressMonitor "always run in background" problem [message #517055 is a reply to message #517024] Thu, 25 February 2010 12:52 Go to previous messageGo to next message
actually, the post you mentioned exactly suggests this, to set a persistent setting :).
WorkbenchPlugin.PlatformUI.getPreferenceStore().setValue( IPreferenceConstants.RUN_IN_BACKGROUND, false );
Doing this will cause a warning, because this is workbench internal. I'm using this in my application
as well and it works. but it is really ugly, of course. so if someone knows a better way i'd be glad to hear
about it.
greetings,
-ben
Am 25.02.2010 20:04, schrieb alopecoid@gmail.com:
> Thank you.
Re: ProgressMonitor "always run in background" problem [message #517394 is a reply to message #517024] Sat, 27 February 2010 09:01 Go to previous messageGo to next message
these settings are stored under in the data location. By default, the
data location is <eclipse-install-folder/workspace. If you delete this
folder the default settings will be used.
HTH
Rüdiger
On 25.02.2010 20:04, alopecoid@gmail.com wrote:
> Thank you.
Re: ProgressMonitor "always run in background" problem [message #517669 is a reply to message #517394] Mon, 01 March 2010 11:17 Go to previous messageGo to next message
Rüdiger Herrmann wrote on Sat, 27 February 2010 09:01
But won't this delete all other settings as well?
It seem to me that this is a bug. There should definitely be a toggle somewhere in the preferences for this.
Re: ProgressMonitor "always run in background" problem [message #517693 is a reply to message #517669] Mon, 01 March 2010 12:48 Go to previous messageGo to next message
yes
This setting can be changed in the WorkbenchPreferencePage.
Re: ProgressMonitor "always run in background" problem [message #517722 is a reply to message #517693] Mon, 01 March 2010 15:18 Go to previous messageGo to next message
Rüdiger Herrmann wrote on Mon, 01 March 2010 12:48
Would you mind telling me exactly how to navigate to this page? I can't seem to find it anywhere.
Just to clarify, I am not an Eclipse developer... I know next to nothing about the Eclipse codebase. It seems that you are referring me to a class name when you write something like "WorkbenchPreferencePage".
I am looking for something more like:
Go to: Window > Preferences > Some Section > Some Other Section. Once there, it's the checkbox labeled "something".
Thank you!
Re: ProgressMonitor "always run in background" problem [message #517741 is a reply to message #517722] Mon, 01 March 2010 12:00 Go to previous messageGo to next message
Window -> Preferences -> General -> uncheck 'always run in background'
I'm just wondering, it seems that this has nothing to do with RAP in particular.
I thought you were refering to a self-build RAP application, i guess that's why
you got the 'codebase' answers.
For questions about the Eclipse IDE itself you should consider asking in the Eclipse
User-Boards, since this is a newsgroup especially for Rich-Ajax-Platform developers.
So most probably you'll get a developer answer here ;)).
HTH,
-ben
Am 01.03.2010 21:18, schrieb alopecoid@gmail.com:
> Thank you!
Re: ProgressMonitor "always run in background" problem [message #517750 is a reply to message #517741] Mon, 01 March 2010 17:24 Go to previous message
Benjamin Wolff wrote on Mon, 01 March 2010 12:00
So most probably you'll get a developer answer here Wink).
HTH,
-ben
Thanks! That worked.
Sorry about that... I thought I just searched in the general forums off of the Eclipse links page, and found a related thread. Not sure how I ended up in this specific forum.
Previous Topic:RAP 1.2
Next Topic:Portlet
Current Time: Thu Mar 13 13:48:11 EDT 2025
Powered by FUDForum. Page generated in 0.06787 seconds
