Home » Language IDEs » Java Development Tools (JDT) » How to do Java Networking across the network?
How to do Java Networking across the network? [message #1072103] Mon, 22 July 2013 04:20 Go to next message
ander zoho is currently offline ander zohoFriend
I have tried java networking tutorial program like TCP chat program. It works on my own computer because it connects to local host, so I can chat with myself. However, when I run the program on separate computers, it doesn't connect. I heard there's restriction because of security in java application from connecting using TCP sockets. What library should I change to? Or what code do I need to change to connect Server/Client sockets
Re: How to do Java Networking across the network? [message #1072256 is a reply to message #1072103] Mon, 22 July 2013 12:04 Go to previous message
Denis Roy is currently offline Denis RoyFriend
Also make sure the ports allow incoming connections on each of the local machines' firewall settings.
Denis Roy
Eclipse Webmaster -- webmaster@eclipse.org
Previous Topic:QuickDiff - using specific SVN revision as a reference source
Next Topic:Can't use Eclipse's UI drag-and-drop interface
Current Time: Wed Feb 05 17:04:56 GMT 2025
Powered by FUDForum. Page generated in 0.03573 seconds
