Windowbuilder "Unhandled event loop exception" No more handles [message #1069187] |
Mon, 15 July 2013 11:15 |
Dan Nicholson Messages: 4 Registered: July 2013 |
I get this message whenever I click from any other window into the Windowbuilder source code editor.
No more handles
This started happening after I ran the updater for the 4.2 last week. It wasn't happening before.
Since then, I have uninstalled all my Java and updated to the latest version (Kepler), but it's doing it there also. Can anyone please help?
I'm kinda new to eclipse and programming in general, so please be gentle.
Edit: I would like to add that if I use the regular code editor I don't get this error. Only in the Windowbuilder code editor.
eclipse.buildId=4.3.0.I20130605-2000
java.version=1.7.0_25
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.jee.product
Error
Mon Jul 15 07:06:14 EDT 2013
org.eclipse.swt.SWTError: No more handles
at org.eclipse.swt.SWT.error(SWT.java:4423)
at org.eclipse.swt.SWT.error(SWT.java:4312)
at org.eclipse.swt.SWT.error(SWT.java:4283)
at org.eclipse.swt.widgets.Widget.error(Widget.java:472)
at org.eclipse.swt.widgets.Control.createHandle(Control.java:704)
at org.eclipse.swt.widgets.Label.createHandle(Label.java:199)
at org.eclipse.swt.widgets.Control.createWidget(Control.java:744)
at org.eclipse.swt.widgets.Control.<init>(Control.java:112)
at org.eclipse.swt.widgets.Label.<init>(Label.java:101)
at org.eclipse.ui.texteditor.StatusLineContributionItem.fill(StatusLineContributionItem.java:182)
at org.eclipse.jface.action.SubContributionItem.fill(SubContributionItem.java:59)
at org.eclipse.jface.action.StatusLineManager.update(StatusLineManager.java:327)
at org.eclipse.ui.internal.WorkbenchPage.updateActivations(WorkbenchPage.java:287)
at org.eclipse.ui.internal.WorkbenchPage.access$15(WorkbenchPage.java:265)
at org.eclipse.ui.internal.WorkbenchPage$E4PartListener.partActivated(WorkbenchPage.java:194)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$2.run(PartServiceImpl.java:183)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.firePartActivated(PartServiceImpl.java:181)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:595)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:539)
at org.eclipse.e4.ui.internal.workbench.swt.AbstractPartRenderer.activate(AbstractPartRenderer.java:104)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer$1.handleEvent(ContributedPartRenderer.java:59)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1057)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1081)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1066)
at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:1453)
at org.eclipse.swt.widgets.Shell.WM_MOUSEACTIVATE(Shell.java:2334)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4655)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:340)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1627)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2075)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4990)
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2544)
at org.eclipse.swt.widgets.Scrollable.callWindowProc(Scrollable.java:80)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4706)
at org.eclipse.swt.internal.win32.OS.PeekMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.PeekMessage(OS.java:3141)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:610)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
[Updated on: Mon, 15 July 2013 11:16] Report message to a moderator
FUDForum. Page generated in 0.08700 seconds
