Home » Archived » BIRT » 2.6.2 report failures with BIRT 4.3
2.6.2 report failures with BIRT 4.3 [message #1066156] Mon, 01 July 2013 05:55 Go to next message
I installed the 4.3 all-in-one release on windows xp and windows 7, and
have the same problem on both with reports developed using BIRT 2.6.2: they
work Ok via the 'run' action when run directly, but when called from a
hyperlink in another report, or when run via the 'preview' action, the
parameters, which are used to filter tables, seem to be corrupted.
No errors are shown, but the report tables are showing content that should
be filtered.
The same report files work perfectly ok with v2.6.2 - the rptdesign is not
changed after opening it with 4.3 and saving.
Is there any documentation on the changes in v4.3 that might help?
Colin Sutton
Re: 2.6.2 report failures with BIRT 4.3 [message #1066620 is a reply to message #1066156] Wed, 03 July 2013 09:29 Go to previous messageGo to next message
I have raised this with further detail as
https://bugs.eclipse.org/bugs/show_bug.cgi?id=412152
Colin
Re: 2.6.2 report failures with BIRT 4.3 [message #1067055 is a reply to message #1066620] Fri, 05 July 2013 11:36 Go to previous messageGo to next message
Can you recreate this with the sample database? As in, create a report in 2.6.2 with the sample db that when ran in 4.3 you see no error but it shows improperly? This way I can see exactly what you're talking about. Thanks!
Re: 2.6.2 report failures with BIRT 4.3 [message #1067119 is a reply to message #1066620] Fri, 05 July 2013 20:38 Go to previous messageGo to next message
I have attached (in bugzilla) a report that I created with 4.3 based on the
sample database that shows that the problem is not only with reports
created with older versions of BIRT.
Re: 2.6.2 report failures with BIRT 4.3 [message #1068278 is a reply to message #1067119] Fri, 12 July 2013 17:46 Go to previous messageGo to next message
If you set a default value for the parameter, the preview of the report shows the correct value. It seems to only happen if you leave the default value setting blank.
Re: 2.6.2 report failure s with BIRT 4.3 [message #1068808 is a reply to message #1068278] Sun, 14 July 2013 08:29 Go to previous messageGo to next message
Thanks, Michael,
I have updated bug 412152 with the work-around.
Colin Sutton
Re: 2.6.2 report failure s with BIRT 4.3 [message #1071239 is a reply to message #1068808] Fri, 19 July 2013 12:18 Go to previous message
Great! Thanks for updating it!
Previous Topic:Text with script not working in frameset but working in preview mode
Next Topic:populate textbox when radio button selected
Current Time: Wed Apr 16 03:47:04 EDT 2025
Powered by FUDForum. Page generated in 0.03771 seconds
