Home » Archived » BIRT » [SOLVED] Problem with date parameters(How do I pass correctly a date parameter?)
[SOLVED] Problem with date parameters [message #1065779] Thu, 27 June 2013 09:06 Go to next message
Hi!
I'm currently trying to represent in my report a list of data obtained from a query that sets a time interval. SO i need to pass 2 dates to my report, a "daystart" end a "dayend".
My query goes like this:
SELECT testuser.username
FROM testuser
WHERE DATE(testuser.reg_time)
BETWEEN ?
AND ?
where testuser.reg_time is a timestamp field.
I know it works because if I input the dates directly, like this:
select testuser.username
from testuser
where date(testuser.reg_time)
BETWEEN '2013/06/03'
AND '2013/06/19'
it gives me exactly what it shoud.
(But only if i use the format YYYY/mm/dd. Others data formats give no results, and I'm thinking this is maybe part of the problem.)
This is the JSP code getting and sending the values:
<birt:parameterPage id="birtTest" reportDesign="report/report1.rptdesign"
name="test"
pattern="frameset"
height="600"
width="800"
format="html"
title="test"
isCustom="true"
showTitle="true"
showToolBar="true"
showNavigationBar="true"
<table border=1>
<tr id = "data1">
<th> Data d'inizio selezione </th>
<td> <input type="date" name="daystart" id="daystart"> </td>
<br><br>
</tr>
<tr id = "data2">
<th> Data di fine selezione </th>
<td> <input type="date" name="dayend" id="dayend"> </td>
</tr>
<br><br>
<tr>
<td colspan = 2><input type="Submit" value="Richiedi il report"></td>
</tr>
</table>
</birt:parameterPage>
The user fills the input fields selecting the data from a javascript app.
The report parameters are set (with the same name as the JSP input) and i linked them with the data set parameters.
I'm sure enough it works to a degree, because there's no occurrence for missing values in the report. So why can't I get my data?
Alas, this portion of the report remains empty, while other dynamic elements are correctly represented. I really don't know where i'm going wrong, and I've already tried a number of things.
Could it depends on the details of the parameters configuration? I tried to set them as date and as string and to convert the timestamps and... well, I tried. I'm open to any suggestion you might have!
Thanks for your patience.
Paolo
[Updated on: Thu, 04 July 2013 06:35] by Moderator
Re: Problem with date parameters [message #1065812 is a reply to message #1065779] Thu, 27 June 2013 10:48 Go to previous messageGo to next message
You might try just setting your query in your dataSet to:
FROM testuser
Then, in your dataSet's beforeOpen script, format the entered parameter value to the format you're wanting. Something like:
importPackage(Packages.java.text);
df = new SimpleDateFormat("yyyy/MM/dd");
ds = df.format(params["daystart"]).toString();
de = df.format(params["dayend"]).toString();
this.queryText = this.queryText + " WHERE DATE(testuser.reg_time)BETWEEN '" + ds + "' AND '" + de + "'";
This way, you control the format that is passed through the query.
Re: Problem with date parameters [message #1065842 is a reply to message #1065812] Thu, 27 June 2013 14:02 Go to previous messageGo to next message
Thanks Micheal!
I'll try it tomorrow, as soon as i'm back to work.
And obviously i'll keep you posted. Smile
Also, sorry for any error in grammar and/or syntax.
My english is not really there... yet.
Re: Problem with date parameters [message #1065902 is a reply to message #1065812] Fri, 28 June 2013 04:22 Go to previous messageGo to next message
Found the Properties section "befoerOpen", but i'm still trying to make your suggestion work.
I keep getting stack errors.
But i keep trying. Smile
[Updated on: Fri, 28 June 2013 06:20] by Moderator
Re: Problem with date parameters [message #1066777 is a reply to message #1065902] Thu, 04 July 2013 06:38 Go to previous messageGo to next message
Hi! I solved the problem setting all parameters as string, and modifing the output of the javascript date-picker to have a yyyy/mm/dd format. SHould have thought of that earlier.
Altought, it still bugs me a little not having been able to solve the problem report-side. ^^"
Thanks for your help!
Re: Problem with date parameters [message #1067073 is a reply to message #1066777] Fri, 05 July 2013 12:53 Go to previous message
No problem. If you want to set up a simple report with the sample database showing exactly what you tried, I can take a look and we can try to get it solved for you in the report.
Previous Topic:Manual page break with DEAPI
Next Topic:birt rhino object literals
Current Time: Wed Apr 16 02:33:58 EDT 2025
Powered by FUDForum. Page generated in 0.05571 seconds
