Re: step by step guide to reverse engineering java code to uml [message #1062163 is a reply to message #841436] |
Thu, 06 June 2013 10:30 |
Junfeng Zhao Messages: 9 Registered: April 2013 |
Hi,Fabien
I discover .uml file from java project by modisco, then explore it by papyrus. Now I have a confusion that I can not view the entire class diagram corresponding to the .uml file and I can view class elements only by drag and drop. I want to know whether there is some method to visulize the entire class diagram. Even we must use papyrus to view the class diagram, I think the relationships between the classes existing in class diagrams should be viewed automatically. Do you think my viewpoint is reasonable? thank you.
[Updated on: Thu, 06 June 2013 10:32] Report message to a moderator
FUDForum. Page generated in 0.06087 seconds
