Home » Language IDEs » C / C++ IDE (CDT) » Make All Doesn't Work (C:\Program:)(C:\Program: C:\Program: No such file or directory)
Make All Doesn't Work (C:\Program:) [message #1053830] Tue, 07 May 2013 19:05 Go to next message
Ahmed Tarhan is currently offline Ahmed TarhanFriend
I'm trying to create build and debug environment for Stm32f4 microcontroller.
Everything was fine for a long time, but today I can't build my project.
I'm using CodeSourcery toolchain.
My Console Output is below;
make all
make: *** [startup_src/startup_stm32f4xx.o] Error 127
I'm looking forward for your suggestions.
Re: Make All Doesn't Work (C:\Program:) [SOLVED] [message #1057848 is a reply to message #1053830] Thu, 09 May 2013 09:59 Go to previous message
Hi;
I solved the problem by changing the path variable.
Right Click To Project->Properties->C/C++ Build->Environment->PATH->Edit
Change all "C:\Program Files(x86)" strings to "C:\PROGRA~2"
and
change all "C:\Program Files" strings to "C:\PROGRA~1"
that solved my problems.
Previous Topic:Using gdb debugger for remote session with gdbserver
Next Topic:set solib-search-path" or "set sysroot error
Current Time: Wed Jan 15 10:35:05 GMT 2025
Powered by FUDForum. Page generated in 0.02552 seconds
