Updating undo/redo labels [message #1041656] |
Mon, 15 April 2013 07:26  |
In my application I have an undo and redo actions which are implemented. It works fine except that the label for the commands in the menu is not modified when an action is performed (e.g. displaying something like "Undo Typing").
This is how I declared them in the plugin.xml:
<extension
point="org.eclipse.ui.menus">
<menuContribution
locationURI="menu:org.eclipse.ui.main.menu">
<menu
label="Edit">
<command
commandId="org.eclipse.ui.edit.undo"
style="push">
</command>
<command
commandId="org.eclipse.ui.edit.redo"
label="Redo"
style="push">
</command>
</menu>
</menuContribution>
</extension>
In my ApplicationActionBarAdvisor I'm doing this:
protected void makeActions(IWorkbenchWindow window) {
register(ActionFactory.UNDO.create(window));
register(ActionFactory.REDO.create(window));
In my editor class I have the following code:
private UndoContext undoContext;
private UndoRedoActionGroup undoRedoActionGroup;
// Called in the init method of the editor
protected void createGlobalActionHandlers() {
undoContext = new ObjectUndoContext(this);
undoRedoActionGroup = new UndoRedoActionGroup(this.getSite(),
undoContext, true);
IActionBars actionBars = getEditorSite().getActionBars();
undoRedoActionGroup.fillActionBars(actionBars);
public void setFocus() {
undoRedoActionGroup.fillActionBars(getEditorSite().getActionBars());
public void executeOperation(IUndoableOperation operation) {
try {
IAdaptable info = getShellAdaptable();
operation.addContext(undoContext);
OperationHistoryFactory.getOperationHistory().execute(operation,
null, info);
undoRedoActionGroup.updateActionBars();
} catch (ExecutionException e) {
e.printStackTrace();
Each operation extends org.eclipse.core.commands.operations.AbstractOperation and specifies its label in the constructor (by calling the super type constructor).
What is missing in my code so that the labels of the operations are displayed in the menu ?
Cédric
Re: Updating undo/redo labels [message #1043826 is a reply to message #1041656] |
Thu, 18 April 2013 03:02  |
I've been trying to debug to see what was happening. The UndoActionHandler setText method is correctly called (with the correct text) and this delegates to a LabelRetargetAction which in the end (simplifying here) ends up calling the commandChanged method of the CommandContributionItem. The code is as follow:
private ICommandListener getCommandListener() {
if (commandListener == null) {
commandListener = new ICommandListener() {
public void commandChanged(CommandEvent commandEvent) {
if (commandEvent.isHandledChanged()
|| commandEvent.isEnabledChanged()
|| commandEvent.isDefinedChanged()) {
updateCommandProperties(commandEvent);
return commandListener;
So, in the nested commandChanged methdo you can see that the updateCommandProperties is called only if one of the 3 conditions is true. Unfortunately, the commandEvent which is passed in has its changedValues field set to 0, which means that none of the condition will be true and the command won't be updated (thus the text in the menu doesn't change).
Higher up in the call stack, the commandEvent is created like this:
boolean enabledChanged = handlerEvent.isEnabledChanged();
boolean handledChanged = handlerEvent.isHandledChanged();
fireCommandChanged(new CommandEvent(Command.this, false,
false, false, handledChanged, false, false, false,
false, enabledChanged));
So the name changed value and description changed value are set to false.
Is this a bug ? Or am I doing something wrong here ? It is so deeply nested in the eclipse framework that it looks like a bug...
[Updated on: Thu, 18 April 2013 03:05] by Moderator
FUDForum. Page generated in 0.02926 seconds
