Home » Eclipse Projects » Gemini » Maven repository for Gemini projects
Maven repository for Gemini projects [message #1033104] Wed, 03 April 2013 21:22 Go to next message
Krzysztof Sobkowiak is currently offline Krzysztof SobkowiakFriend
Could somebody clarify how I can obtain the Gemini Blueprint components using maven? Which maven repository should I use? I need blueprint 1.0.2.RELEASE.
Best regards
Krzysztof
Re: Maven repository for Gemini projects [message #1036267 is a reply to message #1033104] Mon, 08 April 2013 06:47 Go to previous message
Chetan Mising name is currently offline Chetan Mising nameFriend
I was able to get the artifacts from Spring Repo
<dependencies>
 <dependency>
      <groupId>org.eclipse.gemini</groupId>
      <artifactId>org.eclipse.gemini.blueprint.core</artifactId>
      <version>${gemini.version}</version>
      <scope>provided</scope>
    </dependency>
    <dependency>
      <artifactId>org.eclipse.gemini.blueprint.extender</artifactId>
    </dependency>
    <dependency>
      <artifactId>org.eclipse.gemini.blueprint.io</artifactId>
    </dependency>
 </dependencies>
<repositories>
    <repository>
      <id>com.springsource.repository.bundles.release</id>
      <name>SpringSource Enterprise Bundle Repository - SpringSource Bundle Releases</name>
      <url>http//repository.springsource.com/maven/bundles/release</url>
    </repository>
    <repository>
      <id>com.springsource.repository.bundles.external</id>
      <name>SpringSource Enterprise Bundle Repository - External Bundle Releases</name>
      <url>http//repository.springsource.com/maven/bundles/external</url>
    </repository>
  </repositories>
(I had to remove the colon ':' after http as some strange rule does not allow me to post a code snipet with links Sad. So fix the url when using it)
[Updated on: Mon, 08 April 2013 06:48]
Report message to a moderator
Previous Topic:ClassCastException when using reference-list ServiceReference
Next Topic:Using JPA without publishing the persistence unit with Gemini JPA
Current Time: Wed Jan 15 09:17:28 GMT 2025
Powered by FUDForum. Page generated in 0.03279 seconds
