Multiple label in one node [message #1028128] |
Wed, 27 March 2013 21:51 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi !
I would like to know if it's possible to have two label showing two properties on one node.
When i try to do it, the second label is not linked to my node's property, and just show the default value in grey...
Does anyone have an idea about this ?
Thanks a lot !
Valerian
Re: Multiple label in one node [message #1032643 is a reply to message #1028128] |
Wed, 03 April 2013 08:47 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Valerian,
this should work for any number of attributes/labels.
Check your FeatureLabelMappings, if everything is set ok, especially the featurestoedit and featurestodisplay entries.
Thomas
Re: Multiple label in one node [message #1032658 is a reply to message #1032643] |
Wed, 03 April 2013 09:06 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hi Valerian,
you can also use ExpressionLabelMapping in gmfmap. With this you can use OCL to calculate values even from attributes of othe nodes than the one for which the label is displayed.
Ralph
FUDForum. Page generated in 0.04212 seconds
