Home » Archived » Jubula » Some SWT tree nodes are not selected with Select Node by...(This problem appears only with a class extending eclipse Viewpart class)
Some SWT tree nodes are not selected with Select Node by... [message #1011325] Tue, 19 February 2013 05:26 Go to next message
In my application I have two types of SWT trees. One type extend Viewpart, the other extends a home-class extending Viewpart (but not overriding any of its methods). I have no problem using 'Select Node by...' with the first type. But some items are not selected in the second type. They are not selected but the mouse goes over them and the test succeeds. The decoration of the selectable items differs (it 'replaces') from the non-selectable ones (it 'overlays'), but it is also the case within the type 1 trees.
What can I do to solve this problem?
Re: Some SWT tree nodes are not selected with Select Node by... [message #1011333 is a reply to message #1011325] Tue, 19 February 2013 05:42 Go to previous messageGo to next message
But the Check Existence of Node by... succeeds (true).
Re: Some SWT tree nodes are not selected with Select Node by... [message #1011339 is a reply to message #1011333] Tue, 19 February 2013 05:55 Go to previous messageGo to next message
Expand Node by... also works. So it is just the selection that does not work.
Re: Some SWT tree nodes are not selected with Select Node by... [message #1011373 is a reply to message #1011339] Tue, 19 February 2013 07:41 Go to previous messageGo to next message
Removing the decoration does not solve the problem.
[Updated on: Tue, 19 February 2013 07:41] by Moderator
Re: Some SWT tree nodes are not selected with Select Node by... [message #1012771 is a reply to message #1011373] Fri, 22 February 2013 02:55 Go to previous messageGo to next message
Hi Andre,
Are there any logs produced (RC logs for the toollkit), and can you provide a snippet of the code?
What OS are you on?
Are you performing 0 clicks by accident (silly question, but worth checking Wink )
What happens if you perform e.g. 2 clicks?
Alex
Re: Some SWT tree nodes are not selected with Select Node by... [message #1014815 is a reply to message #1012771] Tue, 26 February 2013 09:17 Go to previous messageGo to next message
Alexandra Schladebeck wrote on Fri, 22 February 2013 02:55
Hi Andre,
No error in the log
What OS are you on?
Windows 7
Was really one click. Tried 2 clicks (is supposed to be equivalent in our application to selecting the folder and renaming it; sing the recorder, Jubula recorded only 1 click) and left click with no improvement...
Re: Some SWT tree nodes are not selected with Select Node by... [message #1015007 is a reply to message #1014815] Wed, 27 February 2013 02:56 Go to previous messageGo to next message
Hm. Interesting - any chance of providing a snippet or (even better) a small example AUT that could be attached to a ticket?
Re: Some SWT tree nodes are not selected with Select Node by... [message #1015011 is a reply to message #1015007] Wed, 27 February 2013 03:06 Go to previous messageGo to next message
Hi Alex,
I will review this with our AUT developers today (I am just a tester) and try to come back to you with some code.
I am currently facing too many problems with Jubula so I am considering to revise my decision to use it.
Best regards
Andre
Re: Some SWT tree nodes are not selected with Select Node by... [message #1015043 is a reply to message #1015011] Wed, 27 February 2013 04:34 Go to previous messageGo to next message
Hi Andre,
Thanks for the feedback, and sorry to hear that you're facing problems. Looking at the ones from the forum, it looks like you have the drag and drop problem in tree tables and this one (one possible workaround that comes to mind is selecting by indexpath - does that work?).
If you have other problems or feedback, then please enter them as bugs, or give more details e.g. here or in another thread. If waiting on answers is too long at the moment, then you might want to consider getting some professional support hours from BREDEX so that your questions get answered more quickly and in more detail.
Alex
Re: Some SWT tree nodes are not selected with Select Node by... [message #1015657 is a reply to message #1015043] Fri, 01 March 2013 09:53 Go to previous messageGo to next message
Hi Alex,
I made some tests today with a few (SWT) trees and there it works.
My developer will now have a look at her code.
Andre
Re: Some SWT tree nodes are not selected with Select Node by... [message #1015893 is a reply to message #1015657] Mon, 04 March 2013 03:20 Go to previous message
Thanks for the update - keep us posted!
Previous Topic:Jubula Standalone Build
Next Topic:Should I see the dragged node during a dragNdrop?
Current Time: Wed Sep 17 08:50:04 EDT 2025
Powered by FUDForum. Page generated in 0.11804 seconds
