BIRT ppt report with Office 2010 [message #1008493] |
Tue, 12 February 2013 12:49  |
There is a bug report: Bug 328982 - Cannot open report exported to .ppt in microsoft powerpoint 2010.
It has been marked as "won't fix". Microsoft changed the output format, however with more and more customers upgrading their office products, it seems like a major limitation if it is not to eventually support it. I would like to understand if there is a plan to eventually support this. If there is, what roadmap do you have in mind?
Re: BIRT ppt report with Office 2010 [message #1022652 is a reply to message #1022548] |
Fri, 22 March 2013 05:44   |
Michael Williams wrote on Fri, 22 March 2013 01:07I'm hoping that the plan is released soon. I don't believe the 4.3 version is slated to come out until June or so, anyways, so there would still be some waiting. The plan should tell us more when it's released.
Ok i will wait. But I have a doubt, I'll explain: after opening the ppt file exported with version 4.2.2. I noticed that this file is text as you can see from here:
MIME-Version: 1.0
Content-Type: multipart/related; boundary="___Actuate_Content_Boundary___"
--___Actuate_Content_Boundary___
Content-Location: slide-show
Content-Transfer-Encoding: quoted-printable
Content-Type: text/html; charset="utf-8"
<html
xmlns=3D'http://www.w3.org/TR/REC-html40'
xmlns:o=3D'urn:schemas-microsoft-com:office:office'
xmlns:p=3D'urn:schemas-microsoft-com:office:powerpoint'
xmlns:v=3D'urn:schemas-microsoft-com:vml'
<head>
<meta http-equiv=3D'Content-Type' content=3D'text/html; charset=3Dutf-8'>
<meta name=3D'ProgId' content=3D'PowerPoint.Slide'>
<meta name=3D'Generator' content=3D'Actuate View Server'>
<title>null</title>
<xml><o:DocumentProperties>
<o:Author>null</o:Author>
<o:Description>null</o:Description>
<o:Subject>null</o:Subject>
</o:DocumentProperties></xml><link rel=3DFile-List href=3D'file-list'>
<link rel=3DPresentation-XML href=3D'presentation'>
</head></body></html>
Content-Location: s1
<html
<head/><body><p:slide>
If I open it with PowerPoint 2007 and save it, the file becomes binary (and also opens the PowerPoint2010).
My big problem is: as i should concatenate these files together with the POI, and the ppt generated by birt 4.2.2. can not be open with POI becouse has invalid header (becouse isn't a really ppt file), my question is: with the new version of Birt, the file generated is in the same format (so can not be treated by POI) or is in the correct format with correct header of a normal pptx file?
[Updated on: Fri, 22 March 2013 07:06] by Moderator
Re: BIRT ppt report with Office 2010 [message #1061893 is a reply to message #1022652] |
Tue, 04 June 2013 10:44   |
Mimmo Rossi wrote on Fri, 22 March 2013 05:44Michael Williams wrote on Fri, 22 March 2013 01:07I'm hoping that the plan is released soon. I don't believe the 4.3 version is slated to come out until June or so, anyways, so there would still be some waiting. The plan should tell us more when it's released.
MIME-Version: 1.0
<html
<head>
<title>null</title>
<html
Hi Michael,
but with version 4.3 this problem is solved?
thanks in advance
FUDForum. Page generated in 0.04752 seconds
