Home » Archived » Jubula » Why jubula hangs waited for unlimited time while checking for the text is correct or not?
Why jubula hangs waited for unlimited time while checking for the text is correct or not? [message #1012714] Fri, 22 February 2013 04:57 Go to next message
Rajesh Dash is currently offline Rajesh DashFriend
Member
Why jubula waiting for Unlimited time while checking for the text is correct or not.
Shocked .Is there any one who can help me out in this problem
[Updated on: Fri, 22 February 2013 05:20]
Report message to a moderator
Re: Why jubula hangs waited for unlimited time while checking for the text is correct or not? [message #1012752 is a reply to message #1012714] Fri, 22 February 2013 07:21 Go to previous messageGo to next message
Achim Loerke is currently offline Achim LoerkeFriend
Sorry, but with the amount of information you provided it's next to impossible to even make a guess what the problem might be.
- Achim
Re: Why jubula hangs waited for unlimited time while checking for the text is correct or not? [message #1012797 is a reply to message #1012752] Fri, 22 February 2013 08:38 Go to previous messageGo to next message
Member
I am going to paste the structure of my test cases as this same test case is working fine with the other test suites as i am reusing it again and agian.If i have 10 test cases than some times it is coming at step 6 sometimes it is coming at step 9 so u could not guess when it will come.I have also given the test suites structure
Re: Why jubula hangs waited for unlimited time while checking for the text is correct or not? [message #1014557 is a reply to message #1012714] Tue, 26 February 2013 03:22 Go to previous messageGo to next message
Member
Hi achim ;
I have pasted all the information can you help me to find out the problem
[Updated on: Tue, 26 February 2013 03:22]
Re: Why jubula hangs waited for unlimited time while checking for the text is correct or not? [message #1015002 is a reply to message #1014557] Wed, 27 February 2013 07:53 Go to previous message
Alexandra Schladebeck is currently offline Alexandra SchladebeckFriend
Rajesh - please add test result reports that demonstrate the structure and the problem.
Previous Topic:What should I do to use column title in SelectEntryByTextpath _specifyColumn)
Next Topic:How to switch between 2 aut in windows 7?
Current Time: Sun Dec 22 06:19:57 GMT 2024
Powered by FUDForum. Page generated in 0.04055 seconds
