Re: Generating a config.xml file [message #1011686 is a reply to message #1011130] |
Wed, 20 February 2013 03:41 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Harsha G![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=g.harshagururaj%40gmail.com) Messages: 11 Registered: February 2013 |
Thanks for the quick reply.
My aim is to generate a generic xml which looks like this.
<project>
<modules>
<module name="MainUser" auth="projectManagement">
<view-config>
<list>
<column name="username" />
<column name="forename" />
<column name="surname" />
<column name="email" />
</list>
<form>
<tab label="MainUser Details">
<input name="mainUserPk" />
<input name="username" />
<input name="password" />
<input name="forename" />
<input name="surname" />
<input name="email" />
</tab>
</form>
</view-config>
</module>
<module name="TypeCn">
<view-config>
<list type="">
<column name="typeCnId" />
</list>
<form>
<tab label="Type CN Details">
<input name="typeCnFirst" type="main-data-types/globalcls.ftl"/>
</tab>
</form>
</view-config>
</module>
</modules>
<datatypes>
<input type="id">
<template>
</input>
<input type="descr"></input>
<input type="globalcls"></input>
<input type="prp"></input>
</datatypes>
</project>
In this case, the modules are nothing but Java Models (POJOs) - which i have to pick / select from a java package within the project and the view-config below it are the properties inside the Java Models.
Currently, we are manually writing this xml using tags.
But we want to avoid this and give the user a UI where he can select this modules from a drop-down/ combo-box / picker and configure the properties below it and be able to view the xml at the end. This is when i came across Sapphire and was wondering how to model this case using Sapphire?
I went through the samples but was not able to visualize the same to my case properly. Hope some experts will be able to throw some light on this and give me a head-start in achieving this.
Thanks & Regards,
Harsha
[Updated on: Wed, 20 February 2013 03:57] Report message to a moderator
Re: Generating a config.xml file [message #1015351 is a reply to message #1012732] |
Thu, 28 February 2013 10:14 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
The selected wizard could not be started.
Plug-in "org.eclipse.sapphire.samples" was unable to execute setInitializationData on an instance of "org.eclipse.sapphire.workspace.ui.CreateWorkspaceFileWizard".
java.lang.IllegalArgumentException
Can you tell what might me the problem in this case?
I have cloned one of your sample code to my cases.
[Updated on: Thu, 28 February 2013 12:44] Report message to a moderator
FUDForum. Page generated in 0.05834 seconds
