Opening an editor on a non workspace file [message #99170] |
Thu, 24 July 2003 14:24 |
Originally posted by: bob.donovan.eds.com
I have a requirement to be able to open a source file that is not a member
of the workspace (not managed by the workspace). The file is read as a
part of initialization of my internal model and I would like to give the
user the opportunity to review the customizations contained therein.
Thanks, Bob
Re: Opening an editor on a non workspace file [message #99422 is a reply to message #99170] |
Thu, 24 July 2003 18:43 |
How do you want to open it? In an editor, a view, a dialog? It makes a
difference.
Bob Foster
Re: Opening an editor on a non workspace file [message #99483 is a reply to message #99422] |
Thu, 24 July 2003 20:25 |
Bob,
I want to open it into an Editor.
Since I sent this email, I did some research into the eclipse source and
found that if I subclass IStorageEditorInput, I might be able to get this
to work. Basically I plan to use IStorageEditorInput as a wrapper to an
java.io.File so that I can display it in an Editor.
Since I only want the user to view the file and not edit it, I will have
to turn the editing off. But I still want the file to use the syntax
coloring, outline, etc available for the file extension.
Bob
> difference.
> Bob Foster
Re: Opening an editor on a non workspace file [message #99498 is a reply to message #99483] |
Thu, 24 July 2003 20:51 |
Bob,
Ideally I would like to take a java.io.File and "register" it in Eclipse
as an IFile so that I can take advantage of aspects of using an IFile.
Is this possible?
Bob
Bob Donovan wrote:
> Bob,
> Bob
member
> > difference.
> > Bob Foster
Re: Opening an editor on a non workspace file [message #99510 is a reply to message #99483] |
Bob,
Is this possible?
Bob
Bob Donovan wrote:
> Bob,
> Bob
member
> > difference.
> > Bob Foster
Re: Opening an editor on a non workspace file [message #99523 is a reply to message #99483] |
Bob,
Is this possible?
Bob
Bob Donovan wrote:
> Bob,
> Bob
member
> > difference.
> > Bob Foster
Re: Opening an editor on a non workspace file [message #100659 is a reply to message #99483] |
Sun, 27 July 2003 01:47 |
Originally posted by: ed.burnette.REMOVE.THIS.sas.com
I wrote a plugin that does something like this; see the Fileopen plugin at
www.eclipsepowered.org (open source on sourceforge). Since you don't want to
save the file it's even easier, see the sample code posted for
https://bugs.eclipse.org/bugs/show_bug.cgi?id=2869 . Basically it's the same
idea used by the CVS plugin to view source code on an arbitrary revision, so
that's another place to look. HTH.
Ed Burnette, co-author Eclipse in Action (www.manning.com/gallardo)
"Bob Donovan" <bob.donovan@eds.com> wrote in message
news:bfpfbn$r2b$1@eclipse.org...
> Bob,
> Bob
FUDForum. Page generated in 0.04466 seconds
