Re: ECF container does not get activated with Gemini Blueprint [message #1005500 is a reply to message #1005456] |
Fri, 25 January 2013 17:14 |
Scott Lewis Messages: 1038 Registered: July 2009 |
Hi Joerg,
Simply put, I don't immediately know what's going wrong here. It clearly has something to do with Blueprint's behavior...probably WRT the ECF remote services impl...but I do not know how Blueprint works.
If you are game, I'll help figure this out if you can gather information (through testing your code + Blueprint). But first, have you asked this question on any Blueprint forum? Any insight from that?
Next, it would be helpful if you could paste in a listing of all bundles in your runtime...and their states (e.g. resolved, active, etc)...e.g. by using the OSGi console 'ss' command. What I'm looking for is what the status is of the ECF remote services implementation both before and after Blueprint is supposed to register the remote service. I also want to make sure that you have all the necessary ECF bundles in your running framework.
We can use this forum for interaction, but if you wish it might be useful to have this discussion on the ecf-dev mailing list (see here to sign up):
https://dev.eclipse.org/mailman/listinfo/ecf-dev
That is a more technical list, and it is monitored by more ECF committers (and their help might be useful...as they may have more familiarity with Blueprint than I do).
Scott
Re: ECF container does not get activated with Gemini Blueprint [message #1005695 is a reply to message #1005500] |
Mon, 28 January 2013 10:17 |
Joerg Saini Messages: 8 Registered: January 2013 |
Hi Scott,
I appreciate your reply and effort to seek a solution.
The simplest way to analyze this would be to get the hello example to work with blueprint. I think the DS example is the most appropriate given that, from my experience, DS is quite similar to Blueprint in structure. Got it from the git repository org.eclipse.ecf under examples/bundles. This way, once we get it working it could also be submitted as an additional example on the repository.
First the host bundle (org.eclipse.ecf.examples.remoteservices.hello.ds.host) which I can start using the included product file. Once it is started, I can also view the endpoint in the Service Discovery tab within Eclipse (listed as ecf.osgirsvc). The consumer is not started yet. In this DS invocation the bundle list is as follows:
Bundle list after starting org.eclipse.ecf.examples.remoteservices.hello.ds.host using Declarative Services
0 ACTIVE org.eclipse.osgi_3.8.1.v20120830-144521
1 ACTIVE org.eclipse.ecf.osgi.services.remoteserviceadmin_2.1.0.v20120610-1946
2 ACTIVE org.eclipse.equinox.registry_3.5.200.v20120522-1841
3 ACTIVE org.apache.felix.gogo.runtime_0.8.0.v201108120515
4 ACTIVE org.eclipse.core.runtime_3.8.0.v20120521-2346
5 ACTIVE org.eclipse.equinox.common_3.6.100.v20120522-1841
6 RESOLVED org.eclipse.osgi.services.remoteserviceadmin_1.5.0.v20120610-1946
7 ACTIVE org.eclipse.ecf.provider.jmdns_4.1.0.v20120610-1946
8 ACTIVE org.eclipse.equinox.concurrent_1.0.300.v20120522-2049
9 ACTIVE org.eclipse.equinox.preferences_3.5.0.v20120522-1841
10 ACTIVE org.eclipse.ecf.examples.remoteservices.hello.ds.host_3.0.0.qualifier
11 ACTIVE org.apache.felix.gogo.command_0.8.0.v201108120515
12 ACTIVE org.eclipse.ecf.discovery_4.0.0.v20120610-1946
13 ACTIVE org.eclipse.equinox.app_1.3.100.v20120522-1841
14 ACTIVE org.eclipse.core.contenttype_3.4.200.v20120523-2004
15 ACTIVE org.eclipse.ecf.examples.remoteservices.hello_3.0.100.qualifier
16 ACTIVE org.eclipse.ecf.identity_3.1.200.v20120610-1946
17 ACTIVE org.eclipse.core.jobs_3.5.200.v20120521-2346
18 ACTIVE org.eclipse.equinox.console_1.0.0.v20120522-1841
19 ACTIVE org.apache.felix.gogo.shell_0.8.0.v201110170705
20 ACTIVE org.eclipse.ecf.sharedobject_2.2.100.v20120610-1946
21 ACTIVE org.eclipse.ecf.osgi.services.remoteserviceadmin.proxy_1.0.0.v20120610-1946
22 ACTIVE org.eclipse.equinox.ds_1.4.0.v20120522-1841
23 RESOLVED org.eclipse.osgi.services_3.3.100.v20120522-1822
24 ACTIVE org.eclipse.ecf.osgi.services.distribution_2.0.100.v20120610-1946
25 ACTIVE org.eclipse.ecf.provider.remoteservice_4.0.0.v20120610-1946
26 ACTIVE org.eclipse.equinox.util_1.0.400.v20120522-2049
27 ACTIVE org.eclipse.ecf.provider_4.2.100.v20120610-1946
28 ACTIVE org.eclipse.ecf_3.1.300.v20120610-1946
29 ACTIVE org.eclipse.ecf.remoteservice_6.0.200.v20120610-1946
Then org.eclipse.ecf.examples.remoteservices.hello.ds.consumer is started and proceeds to succesfully perform the remote calls. Its bundle list is as follows:
Bundle list after starting org.eclipse.ecf.examples.remoteservices.hello.ds.consumer using Declarative Services
10 ACTIVE org.apache.felix.gogo.command_0.8.0.v201108120515
11 ACTIVE org.eclipse.ecf.discovery_4.0.0.v20120610-1946
12 ACTIVE org.eclipse.equinox.app_1.3.100.v20120522-1841
13 ACTIVE org.eclipse.core.contenttype_3.4.200.v20120523-2004
14 ACTIVE org.eclipse.ecf.examples.remoteservices.hello_3.0.100.qualifier
15 ACTIVE org.eclipse.ecf.identity_3.1.200.v20120610-1946
16 ACTIVE org.eclipse.ecf.examples.remoteservices.hello.ds.consumer_2.0.0.qualifier
With the above working as expected we proceeded to make changes to introduce Blueprint activation (and remove DS).
org.eclipse.ecf.examples.remoteservices.hello.ds.host/OSGI-INF/hello.xml
<blueprint xmlns="http://www.osgi.org/xmlns/blueprint/v1.0.0" default-activation="eager">
<bean id="host" class="org.eclipse.ecf.examples.internal.remoteservices.hello.ds.host.HelloComponent"/>
<service ref="host" interface="org.eclipse.ecf.examples.remoteservices.hello.IHello">
<service-properties>
<entry key="service.exported.interfaces" value="*" />
<entry key="service.exported.configs" value="ecf.generic.server" />
<entry key="org.eclipse.ecf.containerFactoryArgs" value="ecftcp://localhost:3787/server" />
</service-properties>
</service>
</blueprint>
org.eclipse.ecf.examples.remoteservices.hello.ds.host/META-INF/MANIFEST.MF
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: %bundleName
Bundle-SymbolicName: org.eclipse.ecf.examples.remoteservices.hello.ds.host;singleton:=true
Bundle-Version: 3.0.0.qualifier
Bundle-Vendor: %bundleProvider
Bundle-RequiredExecutionEnvironment: J2SE-1.5,
J2SE-1.4,
CDC-1.1/Foundation-1.1
Import-Package: org.eclipse.ecf.examples.remoteservices.hello;version="3.0.0",
org.eclipse.equinox.app;version="1.1.0"
Bundle-Blueprint: OSGI-INF/hello.xml
Bundle-Localization: bundle
Bundle-ActivationPolicy: lazy
Require-Bundle: org.eclipse.equinox.common;bundle-version="3.6.0"
org.eclipse.ecf.examples.remoteservices.hello.ds.host/products/Hello Service Host DS (zeroconf,generic).product plugins & configurations sections only
<plugins>
<plugin id="org.eclipse.ecf.examples.remoteservices.hello"/>
<plugin id="org.eclipse.ecf.examples.remoteservices.hello.ds.host"/>
<plugin id="org.aopalliance"/>
<plugin id="org.apache.commons.logging"/>
<plugin id="org.apache.felix.gogo.command"/>
<plugin id="org.apache.felix.gogo.runtime"/>
<plugin id="org.apache.felix.gogo.shell"/>
<plugin id="org.eclipse.core.contenttype"/>
<plugin id="org.eclipse.core.jobs"/>
<plugin id="org.eclipse.core.runtime"/>
<plugin id="org.eclipse.ecf"/>
<plugin id="org.eclipse.ecf.discovery"/>
<plugin id="org.eclipse.ecf.identity"/>
<plugin id="org.eclipse.ecf.osgi.services.distribution"/>
<plugin id="org.eclipse.ecf.osgi.services.remoteserviceadmin"/>
<plugin id="org.eclipse.ecf.osgi.services.remoteserviceadmin.proxy"/>
<plugin id="org.eclipse.ecf.provider"/>
<plugin id="org.eclipse.ecf.provider.jmdns"/>
<plugin id="org.eclipse.ecf.provider.remoteservice"/>
<plugin id="org.eclipse.ecf.remoteservice"/>
<plugin id="org.eclipse.ecf.sharedobject"/>
<plugin id="org.eclipse.equinox.app"/>
<plugin id="org.eclipse.equinox.common"/>
<plugin id="org.eclipse.equinox.concurrent"/>
<plugin id="org.eclipse.equinox.console"/>
<plugin id="org.eclipse.equinox.preferences"/>
<plugin id="org.eclipse.equinox.registry"/>
<plugin id="org.eclipse.equinox.util"/>
<plugin id="org.eclipse.gemini.blueprint.core"/>
<plugin id="org.eclipse.gemini.blueprint.extender"/>
<plugin id="org.eclipse.gemini.blueprint.io"/>
<plugin id="org.eclipse.osgi"/>
<plugin id="org.eclipse.osgi.services"/>
<plugin id="org.eclipse.osgi.services.remoteserviceadmin"/>
<plugin id="org.springframework.aop"/>
<plugin id="org.springframework.asm"/>
<plugin id="org.springframework.beans"/>
<plugin id="org.springframework.context"/>
<plugin id="org.springframework.context.support"/>
<plugin id="org.springframework.core"/>
<plugin id="org.springframework.expression"/>
</plugins>
<configurations>
<plugin id="org.eclipse.core.runtime" autoStart="true" startLevel="2" />
<plugin id="org.eclipse.ecf" autoStart="true" startLevel="1" />
<plugin id="org.eclipse.ecf.osgi.services.distribution" autoStart="true" startLevel="1" />
<plugin id="org.eclipse.ecf.osgi.services.remoteserviceadmin" autoStart="true" startLevel="1" />
<plugin id="org.eclipse.ecf.osgi.services.remoteserviceadmin.proxy" autoStart="true" startLevel="1" />
<plugin id="org.eclipse.equinox.app" autoStart="true" startLevel="2" />
<plugin id="org.eclipse.equinox.common" autoStart="true" startLevel="2" />
<plugin id="org.eclipse.gemini.blueprint.core" autoStart="true" startLevel="0" />
</configurations>
Bundle list after starting org.eclipse.ecf.examples.remoteservices.hello.ds.host using Gemini Blueprint
7 STARTING org.eclipse.ecf.provider.jmdns_4.1.0.v20120610-1946
20 STARTING org.eclipse.ecf.sharedobject_2.2.100.v20120610-1946
25 STARTING org.eclipse.ecf.provider.remoteservice_4.0.0.v20120610-1946
26 STARTING org.eclipse.equinox.util_1.0.400.v20120522-2049
27 STARTING org.eclipse.ecf.provider_4.2.100.v20120610-1946
29 STARTING org.eclipse.ecf.remoteservice_6.0.200.v20120610-1946
30 ACTIVE org.eclipse.ecf.examples.remoteservices.hello.ds.host_3.0.0.qualifier
31 ACTIVE org.eclipse.gemini.blueprint.core_1.0.0.RELEASE
32 ACTIVE org.eclipse.gemini.blueprint.io_1.0.0.RELEASE
33 RESOLVED org.springframework.core_3.1.1.RELEASE
34 RESOLVED org.apache.commons.logging_1.1.1.v201101211721
35 RESOLVED org.aopalliance_1.0.0.v201105210816
36 RESOLVED org.springframework.context_3.1.1.RELEASE
39 RESOLVED org.springframework.context.support_3.1.1.RELEASE
40 RESOLVED org.springframework.expression_3.1.1.RELEASE
41 RESOLVED org.springframework.aop_3.1.1.RELEASE
42 RESOLVED org.springframework.beans_3.1.1.RELEASE
43 RESOLVED org.springframework.asm_3.1.1.RELEASE
44 RESOLVED org.eclipse.gemini.blueprint.extender_1.0.0.RELEASE
46 ACTIVE org.eclipse.ecf.examples.remoteservices.hello_3.0.100.qualifier
No errors are reported during startup. However, the service does not get published and the consumer cannot perform the remote calls. Also, nothing appears under Service Discovery in Eclipse. Tried with different startLevels, configurations, etc. but no dice so far.
I can also post the consumer-side changes but I think it's wiser to resolve the above issue before proceeding further.
Joerg
[Updated on: Tue, 29 January 2013 14:49] Report message to a moderator
Re: ECF container does not get activated with Gemini Blueprint [message #1006011 is a reply to message #1005906] |
Tue, 29 January 2013 14:44 |
Consumer-side (org.eclipse.ecf.examples.remoteservices.hello.ds.consumer)
org.eclipse.ecf.examples.remoteservices.hello.ds.consumer/OSGI-INF/helloclient.xml
<bean id="consumer" class="org.eclipse.ecf.examples.internal.remoteservices.hello.ds.consumer.HelloClientComponent"/>
<service ref="consumer" interface="org.eclipse.ecf.examples.remoteservices.hello.IHello" depends-on="host"/>
<reference id="host" interface="org.eclipse.ecf.examples.remoteservices.hello.IHello" availability="mandatory">
<reference-listener bind-method="bindHello">
<ref component-id="consumer" />
</reference-listener>
</reference>
</blueprint>
org.eclipse.ecf.examples.remoteservices.hello.ds.consumer/META-INF/MANIFEST.MF
Bundle-SymbolicName: org.eclipse.ecf.examples.remoteservices.hello.ds.consumer;singleton:=true
Bundle-Version: 2.0.0.qualifier
J2SE-1.4,
org.eclipse.ecf.remoteservice,
org.eclipse.ecf.remoteservice.events,
org.eclipse.equinox.app;version="1.0.0",
org.eclipse.equinox.concurrent.future;version="1.0.0"
Bundle-Blueprint: OSGI-INF/helloclient.xml
Export-Package: org.eclipse.ecf.examples.internal.remoteservices.hello.ds.consumer
org.eclipse.ecf.examples.remoteservices.hello.ds.consumer/products/Hello Service Consumer DS (zeroconf,generic).product plugins & configurations sections only
<plugins>
<plugin id="org.eclipse.ecf.examples.remoteservices.hello.ds.consumer"/>
<plugin id="org.eclipse.gemini.blueprint.core" version="1.0.2.RELEASE"/>
<plugin id="org.eclipse.gemini.blueprint.extender" version="1.0.2.RELEASE"/>
<plugin id="org.eclipse.gemini.blueprint.io" version="1.0.2.RELEASE"/>
<plugin id="org.springframework.aop" version="3.1.1.RELEASE"/>
<plugin id="org.springframework.asm" version="3.1.1.RELEASE"/>
<plugin id="org.springframework.beans" version="3.1.1.RELEASE"/>
<plugin id="org.springframework.context" version="3.1.1.RELEASE"/>
<plugin id="org.springframework.context.support" version="3.1.1.RELEASE"/>
<plugin id="org.springframework.core" version="3.1.1.RELEASE"/>
<plugin id="org.springframework.expression" version="3.1.1.RELEASE"/>
</plugins>
<configurations>
<plugin id="org.eclipse.ecf" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.ecf.osgi.services.distribution" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.ecf.osgi.services.remoteserviceadmin" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.ecf.osgi.services.remoteserviceadmin.proxy" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.ecf.provider" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.ecf.provider.jmdns" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.equinox.app" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.gemini.blueprint.extender" autoStart="true" startLevel="0" />
</configurations>
With the above adaptations the synchronous remote call via proxy completes successfully using Gemini Blueprint.
However, the asynchronous remote call with callback fails with:
WARNING: Custom method [public void org.eclipse.ecf.examples.internal.remoteservices.hello.ds.consumer.HelloClientComponent.bindHello(org.eclipse.ecf.examples.remoteservices.hello.IHello)] threw exception when passing service [$Proxy2@58714e00]
java.lang.ClassCastException: $Proxy2 cannot be cast to org.eclipse.ecf.remoteservice.IRemoteServiceProxy
After looking into this it appears that when using DS the proxy instance is of type org.eclipse.ecf.provider.remoteservice.generic.RemoteServiceImpl whereas with Blueprint the proxy is of type org.springframework.aop.framework.JdkDynamicAopProxy (thus the ClassCastException). I'll keep looking... any advice is welcome.
[Updated on: Tue, 29 January 2013 16:19] Report message to a moderator
Re: ECF container does not get activated with Gemini Blueprint [message #1006481 is a reply to message #1006147] |
Thu, 31 January 2013 13:09 |
When using DS the proxy is created by ECF and in particular org.eclipse.ecf.remoteservice.AbstractRemoteService$ProxyClassLoader. The createProxy() methods seem overly likely (even though I haven't verified through a debug session yet).
The generated instance implements the following interfaces:
interface org.eclipse.ecf.examples.remoteservices.hello.IHello,
interface org.eclipse.ecf.examples.remoteservices.hello.IHelloAsync,
interface org.eclipse.ecf.remoteservice.IRemoteServiceProxy
When using Blueprint the proxy creation appears to be handled through Gemini Blueprint only, involving the org.eclipse.gemini.blueprint.context.support.internal.classloader.ChainedClassLoader.
In this case the generated proxy implements the interfaces:
interface org.eclipse.gemini.blueprint.service.importer.ImportedOsgiServiceProxy,
interface org.springframework.aop.IntroductionInfo,
interface java.io.Serializable,
interface org.springframework.core.InfrastructureProxy,
interface org.springframework.aop.SpringProxy
Should the proxy creation have been delegated to ECF in the second case? Is there a way to cause this?
I'll put together a post to the Gemini forum as well.
[Updated on: Thu, 31 January 2013 13:16] Report message to a moderator
FUDForum. Page generated in 0.04502 seconds
