Complex table structure using Nebula [message #993962] |
Wed, 26 December 2012 02:18 |
Prashant p Messages: 57 Registered: October 2012 |
Member |
I have a table with multiple rows which will be dynamic. In between these rows i will have summary row to count Sub Total Amount and Final row will be Summary row to populate Total Amount. Each row will contain Amount of particular Item.
For example
Category1 -Item1 -100 USD,
-Item2 -200 USD.
Subtoatal to Category 1 - 300 USD.
Category2 -Item1 -300 USD,
-Item2 -100 USD.
Subtoatal to Category 1 - 400 USD.
Now total Amount row will add subtotal amount of each category i.e 700 USD.
Is there any option to achieve this using Nebulla. Basically i am trying to replicate Webpage Table to SWT/Jface . Attached is the screenshot. Also please note that values in table will be populated from Database
Attachment: Table1.png
(Size: 34.31KB, Downloaded 494 times)
[Updated on: Wed, 26 December 2012 03:31] Report message to a moderator
Re: Complex table structure using Nebula [message #995721 is a reply to message #994961] |
Mon, 31 December 2012 00:28 |
Member |
Thanks Edwin and Thomas. Do you mean Jface Grid Thomas? Also is it possible to populate DB values in Nat Table? 'coz my main intention is to populate table with DB values. And I should be able to add new row on ADD button click and insert values to DB. And also should be able to edit. Why i am asking this is Nat table is like Virtual table.
[Updated on: Mon, 31 December 2012 00:41] Report message to a moderator
FUDForum. Page generated in 0.06244 seconds
