Re: P2 Update in E4 RCP Application [message #1000797 is a reply to message #1000751] |
Tue, 15 January 2013 12:53 |
Have you enabled the "Generate metadata repository" option? I'm don't remember if the PDE Export Product Wizard produces an updateable product but this option ensures that it will produce a p2 repository containing the product from which you can materialize an update able product using the "p2 director".
I highly recommend that you look to setting up a headless build, such as Tycho or Buckminister.
Brian.
Re: P2 Update in E4 RCP Application [message #1002507 is a reply to message #1002442] |
Fri, 18 January 2013 18:22 |
Christoph -- there's a setting under the '"Configuration" tab (from memory) called "Support software installation" that will spoof up a p2 profile. But for real debugging you'll need to run your app standalone and attach using the remote debugging facilities.
Brian.
FUDForum. Page generated in 0.03267 seconds
