Rename - Refactor hotkey inserts registered trademark symbol [message #987714] |
Tue, 27 November 2012 17:27 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Matt Burke![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=burkemw3%40gmail.com) Messages: 3 Registered: November 2012 |
Previously, using the ALT+COMMAND+R key combination after highlighting a variable name in a Java file would go into the rename refactor mode. Now, the key combination replaces the highlighted text with a registered trademark symbol. How can I get the key combination to go into the rename refactor mode instead of inserting the symbol?
The current file encoding is set to MacRoman, which is the default setting inherited from container. As far as I know, nothing here has changed.
I am using Eclipse Indigo (Build id: 20110615-0604) on Mac OS X 10.7.5. Eclipse IDE for Java EE Developers 1.4.0.20110615-0550 and FreeMarker IDE SDK 1.1.0.v201006011046R-H111-GA are installed. I don't think there are any non-standard plugins.
The only recent change I can remember making is installing PyDev last week. With the default PyDev installed, ALT+COMMAND+R opens a context menu in the lower right corner with 2 option: rename and set next symbol (this is in addition to replace the text with the symbol). I disabled the Set Next Symbol key binding in my preferences, restarted eclipse, and tried the key combo again. The text was still replaced by the symbol but the rename refactor mode was not entered did not open. I uninstalled PyDev, restarted eclipse, and tried the key combo again. The text was still replaced by the symbol.
FUDForum. Page generated in 0.03390 seconds
