Home » Modeling » TMF (Xtext) » Could you do Pascal in XText
Could you do Pascal in XText [message #30710] Fri, 27 February 2009 09:06 Go to next message
Hi all,
A quick question: would XText be able to cope with a grammar as big as
that of Pascal? Will the result be usable performance wise?
Tonny Madsen
Re: Could you do Pascal in XText [message #30753 is a reply to message #30710] Fri, 27 February 2009 16:35 Go to previous messageGo to next message
Hi Tonny,
I don't know pascal good enough to say whether it can be parsed with TMF
Xtext at all. But after having a quick look over the corresponding
Antlr 2 grammar (http://www.antlr.org/grammar/pascal/pascal.g), I'ld say
yes.
Regarding performance : Usually, the size of the files and the
implementation of the static analysis and linking is more important than
the size of the grammar.
We haven't tried to implement a general purpose programming language
with TMF Xtext so far. Would be very interesting to see that ;-).
Sven
Tonny Madsen schrieb:
> Hi all,
> Tonny Madsen
Re: Could you do Pascal in XText [message #30787 is a reply to message #30753] Sun, 01 March 2009 16:12 Go to previous messageGo to next message
Well, we might do just that as a first version for a Pascal editor as
Xtext seems to provide all the functionality that is asked for for now.
We already have the ANTLR grammar in place :-), so we really just have
to try. If we do try this out for real, then be sure that we will notify
you of any results...
Tonny
Sven Efftinge wrote:
> Hi Tonny,
> yes.
> Cheers,
> Sven
>> Hi all,
>> Thanks,
>> Tonny Madsen
Newbie - EMF/ANTLR or xtext? [message #31423 is a reply to message #30787] Wed, 11 March 2009 09:57 Go to previous messageGo to next message
Hi there,
My name is Christophe Bouhier, I am working on a rather large
application with RCP, EMF, GMF etc...
For the last few weeks, I was trying to generate code from a DSL which
can "act" on my EMF model. "act" here is defined as query, process and
write back to EMF.
I am using ANTLRv3, created a grammar, AST and working on templates to
generate OCL to do the "acting".
On top, I have been trough the hassle to define a text editor, which can
enrich my DSL. (syntaxhighlighting etc...)
Now, I asked a question on the EMF forum, if this a good approach, and
I was pointed out to the xtext project which I didn't know about.
At a first glance, xtext seems to be what I need, and I wouldn't need to
be bothered with the DSL text editor. (Bummer, how can I have missed out
on this project!).
Looking at the documentation, I am however uncertain if xtext can cover
my requirements. So, I turn to you and ask:
- xtext looks very similar to antlrv3 grammar, but seems to have
simplications, is it somewhere documented what the differences are?
- as discussed in the thread on pascal.g below, my DSL is also as rich
as a general purpose language, so would xtext be able to handle a
complex language with flow statements (if, for, while, switch) and other
language constructs (OO like inheritance, woudln't be required tough, so
it's somewhat simplified)?
- xtext seems to have been conceived to create a model (I read Sven's
blog on diagram vs text for modelling. My requirement is not to model,
as I did use text already (.XSD) :-) but to perform operations on the
model. Does xtext fit the bill?
- What does xtext provide, to perform what I defined as "acting" on the
model? (Do I need to generate OCL templates to "act" on my model?, is
there an alternative)
Please help me understand if what I need can be achieved xtext
Thanks, Christophe
> Tonny
>> Hi Tonny,
>> TMF Xtext at all. But after having a quick look over the
>> corresponding Antlr 2 grammar
>> (http://www.antlr.org/grammar/pascal/pascal.g), I'ld say yes.
>> than the size of the grammar.
>> Cheers,
>> Sven
>>> Hi all,
>>> as that of Pascal? Will the result be usable performance wise?
>>> Thanks,
>>> Tonny Madsen
Re: Newbie - EMF/ANTLR or xtext? [message #31459 is a reply to message #31423] Wed, 11 March 2009 12:00 Go to previous messageGo to next message
Hi Christophe,
I'll comment inline...
I'm not sure I understand. Do you have a language, which operates
against EMF models, i.e. Ecore is the typesystem?
Well it's not completely documented yet. Updating the documentation is a
highly prioritized task for the upcoming M7.
The available documentation can be found here
http://wiki.eclipse.org/Xtext/Documentation
We don't have new insights regarding this, so we still are pretty sure
that it shouldn't be a problem.
Xtext "just" provides textual syntax including IDE support for existing
ecore models. So the parser creates an EMF model which can than further
be used for anything.
Eclipse Modeling provides a vast number of different languages and
solutions to process EMF models. One is OCL another is M2T Xpand, which
Xtext itself uses for code generation.
There are two different ways of "acting on models".
Code generation: Can be done e.g with Xpand
Interpretation : Usually done with Java (use the Switch class EMF
generates for you) as well as OCL, Xpand'x expression language, etc.
Xtext itself does not provide a specific solution, as there are
solutions available.
regards,
Sven
Re: Newbie - EMF/ANTLR or xtext? [message #31564 is a reply to message #31459] Thu, 12 March 2009 04:51 Go to previous messageGo to next message
Hi Sven,
Thanks for the response, see my reply inline.
Yes, the model represents a telecom network.
define Router{
traffic_in = DEFAULT_TRAFFIC
traffic_out = traffic_in - DROPPED_PACKETS
So "Router", "traffic_in", "DEFAULT_TRAFFIC" are all EMF elements
somewhere in the EMF model tree.
So the user would write these scripts instead of OCL or any other way to
read and write to EMF.
The scripts are written and interpreted at runtime, so building in
these rules into the EMF model itself when building the model is not an
option.
Ok, will have a closer look here.
Ok, worth a try then.
So, can xtext use an existing EMF model, or does it always have to
create one.
I'll need to look into Xpand, as I am not familiar with it.
> regards,
> Sven
Re: Newbie - EMF/ANTLR or xtext? [message #31629 is a reply to message #31564] Thu, 12 March 2009 07:14 Go to previous message
>> existing ecore models. So the parser creates an EMF model which can
>> than further be used for anything.
>> which Xtext itself uses for code generation.
> create one.
Yes, one can use any number of existing EMF models in a grammar.
We have some languages in our test suite showing how it basically works.
Of course, the documentation will cover it as well.
regards,
Sven
Previous Topic:[Announce] TMF XTEXT 0.7.0 I200903111305 is available
Next Topic:[Xtext] Start/use generated DSL editor
Current Time: Thu Sep 18 08:38:34 EDT 2025
Powered by FUDForum. Page generated in 0.36968 seconds
