Home » Eclipse Projects » Eclipse Platform » "Cannot connect to VM" when trying to Debug
"Cannot connect to VM" when trying to Debug [message #300403] Wed, 08 March 2006 11:22 Go to next message
Originally posted by: e0326320.student.tuwien.ac.at
I use winXP, SP2, Eclipse 3.1.1, JDK1.5.0_06, JRE1.5.0_06.
Everything worked fine until a few days ago:
If i want to Debug a (local) Java Application i get the Message "Cannot
connect to VM" when i hit dem "Debug"-Button!!!
I tried with Eclipse 3.0 but there i have the same Problem. In Eclipse 3.0 i
get also an Stack-Trace:
>> java.net.BindException: Address already in use: JVM_Bind
>> java.net.PlainSocketImpl.socketBind(Native Method)
>> java.net.PlainSocketImpl.bind(Unknown Source)
>> java.net.ServerSocket.bind(Unknown Source)
>> java.net.ServerSocket.<init>(Unknown Source)
>> org.eclipse.jdi.internal.connect.SocketTransportImpl.listen( SocketTransportImpl.java:56)
>> org.eclipse.jdi.internal.connect.SocketListeningConnectorImp l.startListening(SocketListeningConnectorImpl.java:103)
>> org.eclipse.jdt.internal.launching.StandardVMDebugger.run(St andardVMDebugger.java:196)
>> org.eclipse.jdt.internal.launching.JavaLocalApplicationLaunc hConfigurationDelegate.launch(JavaLocalApplicationLaunchConf igurationDelegate.java:109)
>> org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:569)
>> org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:788)
>> org.eclipse.debug.internal.ui.DebugUIPlugin$6.run(DebugUIPlu gin.java:955)
>> org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
I didn't change any settings concerning windows, eclipse or java. I have no
Firewall installed, except the WinXP-SP2-Firewall. But also when it is not
active the error occours.
I have no idea why there should be an "Address already in use"....this
Problem is annoying...i hope someone can help me!! Otherwise i have to
reinstall my entire system.
Franz-Stefan
Re: "Cannot connect to VM" when trying to Debug [message #300472 is a reply to message #300403] Thu, 09 March 2006 09:59 Go to previous messageGo to next message
Hi Franz-Stefan,
have you tried another port for remote debug already?
Vera
> Franz-Stefan
Re: "Cannot connect to VM" when trying to Debug [message #300558 is a reply to message #300472] Sun, 12 March 2006 06:39 Go to previous messageGo to next message
No. I didn't know that i can do that and i don't know how i can do that, so:
how can i do that?
Now i noticed that the Help of my Eclipse is also not working. If i want to
run the Help->Help Contents i get an error "Help cannot be displayed. The
embeded application server could not run help web application. Check the log
for details.". I suppose that this error is is related to my "Cannot connect
to VM"-Error....
Franz-Stefan
> Vera
>> 3.0 i get also an Stack-Trace:
>> no Firewall installed, except the WinXP-SP2-Firewall. But also when it is
>> not active the error occours.
>> Franz-Stefan
Re: "Cannot connect to VM" when trying to Debug [message #300582 is a reply to message #300558] Mon, 13 March 2006 03:33 Go to previous message
> how can i do that?
Choose Menu Run -> Debug
Configure Remote Java Application -> Connection Properties -> Port
Change the vm options when starting the java application (you want to debug)
Here my options for example: -Xms64m -Xmx128m -Xdebug -Xnoagent
-Djava.compiler=NONE
-Xrunjdwp:transport=dt_socket,server=y,suspend=n,address=801 0
Previous Topic:Can I update the Platform through a proxy?
Next Topic:integrating EMF application
Current Time: Tue Oct 21 02:45:40 EDT 2025
Powered by FUDForum. Page generated in 0.04054 seconds
