Eclipse plug-in RCP failing while exporting [message #299521] |
Mon, 20 February 2006 06:32  |
Originally posted by: javo.sentim.com
Hello there,
I have a project which is running well inside Eclipse, but as soon as I am
exporting it to a directory outside of Eclipse it says:
1. ERROR in D:\eclipse3.1WTP0.7Sysdeo31b\project1\packg\xyz.java
(at line 25)
import org.eclipse.ui.forms.FormColors;
The import org.eclipse.ui.forms cannot be resolved
I am importing this class in a jar to the project. I have tried to
signalise this in many places in the plug-in configuration files without
success. Why is the wizard not including the external jars?
I tried to add the jars to the target directory manually also
unsuccessfully...
any ideas?
PS: I tested exporting before adding the class with the import and it
worked.
FUDForum. Page generated in 0.16594 seconds
