Home » Newcomers » Newcomers » Help in Eclipse under XP Still Not Working
Help in Eclipse under XP Still Not Working [message #29913] Sat, 05 March 2005 16:46 Go to next message
Originally posted by: jim_stanley.earthlink.net
Folks,
I'm still trying to get the help engine going under XP and am having no
luck. Ron suggested trying to start it up independently and I'm a
little confused translating Linux to XP. As I understand it, there are
a few possible command lines to get this going:
java -classpath (eclipse_home)/plugins/org.eclipse.help.base_3.0.1\
-command start -eclipsehome (eclipse_home) -port 8081
Which I'm translating to XP as:
java -classpath "C:\Program Files\Eclipse\org.eclipse.help.base_3.0.1"
-command start -eclipsehome "C:\Program Files\Eclipse" -port 8081
This gives me the message that the -command option is invalid in the JVM
(1.4.1)
Trying:
Files\Eclipse\org.eclipse.help.base_3.0.1\helpbase.jar" -command start
gives me the same result.
Ron also had another reference to "infocenter", so I tried the following:
org.eclipse.help.standalone.Infocenter -command start -eclipsehome
which now tells me it can't find the class
org/eclipse/help/standalone/Infocenter.
Could someone *please* tell me what's going on? This is a brand-new
machine, so there should be little on it to screw things up. I've done
some logging before, so if anyone could help out a newbie to try and
start a log to see what's going on, I'd be obliged. But I'm stuck at
square one without being able to see any help.
Sorry for the frustration.
Jim Stanley
Media Services
Re: Help in Eclipse under XP Still Not Working [message #29921 is a reply to message #29913] Sun, 06 March 2005 05:21 Go to previous message
Originally posted by: muhammad.dwyer.gmail.com
Hello Jim,
Are you usijng a firewall such as ZoneAlarm? I had problems in the past with
ZoneAlarm and Eclipse help. Just an idea.
> Folks,
> no luck. Ron suggested trying to start it up independently and I'm a
> are a few possible command lines to get this going:
> JVM (1.4.1)
> Trying:
> following:
> done some logging before, so if anyone could help out a newbie to try
> and start a log to see what's going on, I'd be obliged. But I'm stuck
> at square one without being able to see any help.
> Jim Stanley
> Media Services
Previous Topic:javaw.exe - no disk
Next Topic:number of line
Current Time: Tue Sep 16 00:30:47 EDT 2025
Powered by FUDForum. Page generated in 0.06878 seconds
