Home » Newcomers » Newcomers » Cannot run help from eclipse
Cannot run help from eclipse [message #29904] Fri, 04 March 2005 15:25 Go to next message
Originally posted by: billferrett.blueyonder.co.uk
I'm not exactly a newbie but I have always had problems running eclipse
"Help Contents". I am currently running 3.1.M5b but it has been the
same story since 2.x. A window opens, title
"http://127.0.0.1/help/index.jsp" but it is empty. There do not appear
to be any errors in the org.eclipse.tomcat log.
If I try "http://127.0.0.1" from a browser I get "Internal Application
Server" (so it must have been started) then I am redirected to an empty
index.jsp page.
If I try "http://127.0.0.1/help/about.html" I get the about.hmtl from
"eclipse/plugins/org.eclipse.help.webapp_3.0.0".
So it looks like html files are served ok but the problem is jsp's.
When I try "http://127.0.0.1/help/index.jsp" from a browser I get the
following errors:
StandardWrapper[/help:org.eclipse.help.internal.webapp.jsp.b asic.index_jsp]:
Marking servlet org.eclipse.help.internal.webapp.jsp.basic.index_jsp as
unavailable
StandardWrapperValve[org.eclipse.help.internal.webapp.jsp.ba sic.index_jsp]:
Allocate exception for servlet
javax.servlet.ServletException: Error instantiating servlet class
java.lang.LinkageError: loader constraints violated when linking
javax/servlet/http/HttpServletResponse class
I have removed all versions of servlet.jar except that in
eclipse\plugins\org.eclipse.tomcat_4.1.30 as I suspected there could be
duplicate classes on the classpath. I don't have a CLASSPATH envar.
Finally, if I put an index.jsp file in
eclipse\plugins\org.eclipse.tomcat_4.1.30\webapps\ROOT and try
"http:\\127.0.0.1\index.jsp" I get an Error 500 and the log contains:
Error compiling file:
E:\Projects\Eclipse\.metadata\.plugins\org.eclipse.tomcat\RO OT\/index_jsp.java
[javac] Compiling 1 source file
[javac]
E:\Projects\Eclipse\.metadata\.plugins\org.eclipse.tomcat\RO OT\index_jsp.java:3:
package javax.servlet does not exist
[javac] import javax.servlet.*;
Info: Compile:
javaFileName=E:\Projects\Eclipse\.metadata\.plugins\org.ecli pse.tomcat\ROOT\/index_jsp.java
classpath=null
cp=null
work
dir=E:\Projects\Eclipse\.metadata\.plugins\org.eclipse.tomca t\ROOT
srcDir=E:\Projects\Eclipse\.metadata\.plugins\org.eclipse.to mcat\ROOT
include=index_jsp.java
Exception compiling Compile failed; see the compiler error output for
details.
Exception:
Compile failed; see the compiler error output for details.
at org.apache.tools.ant.taskdefs.Javac.compile(Javac.java:938)
So it seems that Eclipse still knows how to handle jsp's but the
classpath is empty.
How can I find out what the classpath is used when "Help Content" fails?
All of this is straight out of the box so to speak. I unzipped the
install file, started it up and got these results. After a day trying
to fathom it out I'm still stumped. The main reason for persevering is
that I want to set up an Info Center for an app I'm developing and need
to understand how the help component works.
Re: Cannot run help from eclipse [message #29909 is a reply to message #29904] Fri, 04 March 2005 21:27 Go to previous message
What is in your java extensions folder? On Mac OS X, there is a place to
put jars that one wants to use (I think on Linux this will be in some bin
folder). I found that if I put log4j.jar into my classpath, help stopped
working in Eclipse. No idea why but when I took it out, Help worked
flawlessly.
On 3/4/05 1:25 PM, in article d0ag7j$8ib$1@www.eclipse.org, "Bill Ferrett"
> index.jsp page.
> following errors:
> unavailable
> [javac]
> 3:
> Info: Compile:
> ndex_jsp.java
> classpath=null
> cp=null
> work
> details.
> Exception:
> classpath is empty.
Previous Topic:Emacs in Eclipse
Next Topic:javaw.exe - no disk
Current Time: Fri Apr 25 19:25:19 EDT 2025
Powered by FUDForum. Page generated in 0.10805 seconds
