| Problems related to the development of an Eclipse debugger [message #296293] |
Tue, 20 December 2005 03:10  |
Originally posted by: zdrey.irisa.fr
I have implemented an Eclipse debugger using the Eclipse Debug Framework
(I am using eclipse 3.1.1). After having launched and terminated a
first time a program in the Debug mode, I got the following error when I
then try to launch a Runtime Workbench :
java.lang.IllegalStateException
org.eclipse.update.configurator.ConfiguratorUtils.getPlatfor mConfiguration(ConfiguratorUtils.java:68)
org.eclipse.pde.internal.core.TargetPlatform.createPlatformC onfigurationArea(TargetPlatform.java:134)
org.eclipse.pde.internal.ui.launcher.WorkbenchLaunchConfigur ationDelegate.getProgramArguments(WorkbenchLaunchConfigurati onDelegate.java:171)
org.eclipse.pde.internal.ui.launcher.WorkbenchLaunchConfigur ationDelegate.createVMRunner(WorkbenchLaunchConfigurationDel egate.java:106)
org.eclipse.pde.internal.ui.launcher.WorkbenchLaunchConfigur ationDelegate.launch(WorkbenchLaunchConfigurationDelegate.ja va:79)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:590)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:515)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:733)
org.eclipse.debug.internal.ui.DebugUIPlugin$6.run(DebugUIPlu gin.java:931)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
I cannot figure out where the problem come from, neither do I know what
is a platform configuration... Could someone help me?
Thanks in advance,
Zoé
| Re: Problems related to the development of an Eclipse debugger [message #296298 is a reply to message #296293] |
Tue, 20 December 2005 04:47  |
[Resolved]
For those who are interested : the problem came from the fact that I had
set a special SecurityManager (using System.setSecurityManager
method) to allow a proper RMI communication between the debugger and
the GUI (Eclipse side) : simply resetting the SecurityManager to "null"
after the debug execution is terminated resolves the mentioned problem.
zdrey wrote:
> Hello,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks in advance,
FUDForum. Page generated in 0.03818 seconds
