| Find IVMInstall with minimum version [message #296193] |
Fri, 16 December 2005 11:44  |
I'm writing a plugin to set up new Java projects that meet my company's
internal standards. One of the standards is to use Java 5, so I would
like to ensure that the VM for the project is one that supports Java 5. I
cannot seem to find a way to programmatically find which IVMInstalls
support Java 5.
Right now, I'm just using JavaRuntime.getDefaultJREContainerEntry(), which
works only if they have Java 5 as their default VM, which isn't the case
for a lot of folks.
Any suggestions?
Scott
| Re: Find IVMInstall with minimum version [message #296196 is a reply to message #296193] |
Fri, 16 December 2005 11:53  |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Try seeing if the IVMInstall instance also implements IVMInstall2.
IVMInstall2 has a method to return the java version. it may not be able
to return it, so you check for that case too.
Scott Rankin wrote:
> Hello,
> I cannot seem to find a way to programmatically find which IVMInstalls
> support Java 5.
> which works only if they have Java 5 as their default VM, which isn't
> the case for a lot of folks.
> Any suggestions?
> Scott
Rich Kulp
FUDForum. Page generated in 0.05979 seconds
