Home » Archived » Visual Editor (VE) » JSP/HTML
JSP/HTML [message #2550] Thu, 20 November 2003 14:51 Go to next message
"The Eclipse Visual Editor project is a framework .... for creating GUI
builders for other languages such as C/C++ and alternate widget sets,
including those that are not supported under Java."
I believe I read somewhere that to generate the swing widgets a seperate
JVM is generated that is used to "draw" the images in the editor by
actually "running" the code (I realize this is probably a gross
oversimplification).
I'm assuming that this is only a possible mechanism to generate the
onscreen view of the widget. From those who have worked with the code
before, is it possible (realistically) to build upon this framework to
create a JSF/HTML GUI editor?
Curious as to what mechanism could be used to generate the widgets on
screen?
Chris....
Re: JSP/HTML [message #2582 is a reply to message #2550] Thu, 20 November 2003 16:21 Go to previous messageGo to next message
Hi Chris,
No - that's a pretty good summary of what occurs. What happens is that a
separate JVM sandbox is created whose classpath is the buildpath of the
project. You have an object model in the IDE of the GUI and its elements
created from parsing the code and then you proxy each component to their
live ones in the target JVM. The GUI stuff off-screen so you can't see it,
and the image of this captured and then drawn in GEF which uses an SWT
Canvas. This means you're working with a cartoon of the live widgets. One
thing we want to do as well is leverage this so we can do lots of techniques
that are found in other drawing tools where the drawing is exploded to
exaggerate features or allow additional manipulation points for the GUI, so
it's not always a flat direct drawing of the live widgets but instead is
more of an annotated cartoon.
> screen?
The only real requirement on the live GUI is that you can work out what it
looks like, and also the size and location of each component. For HTML one
idea we were toying around with a while back was having DHTML that can get
you the bounds of each DOM element, and then some Java script to allow a
socket to be opened between the IDE and the browser allowing this
information to go back and forth. There is also the possibility of
pervasive devices where you want to work with a true cartoon of the device's
rendering rather than emulation. Even with just Swing itself you can
develop for a JRE level that is totally separate to the IDE JRE.
Joe
Re: JSP/HTML [message #2640 is a reply to message #2582] Thu, 20 November 2003 20:05 Go to previous messageGo to next message
Originally posted by: pascal_rapicault.yahoo.fr
I'm just curious: From the "picture" the vm gives you, how do you recognize
what is a widget, and which type of widget is it to draw it in gef?
Can you point me at the code that "get the picture "from the VM?
Thank you,
PaScaL
"Joe Winchester" <winchest@uk.ibm.com> a
Re: JSP/HTML [message #3780 is a reply to message #2582] Fri, 21 November 2003 08:51 Go to previous messageGo to next message
Originally posted by: Michael.Dag.removeIFnoSPAM.planet.nl
Joe,
I stumbled upon this, but I am not a programmer, just a not so stupid
user...
<clip>
One
techniques
so
</clip>
Can you elaborate on what you mean here?
One drawing tool I work with is Visio, which besides excellent drawing
capabilities has 'rich' programming support (from an end-user
perspective...), could a spin-off of VE be an opensource turbo charged Visio
environment?
I know Microsoft in Visio 2003 have enabled the use of Visio drawing
controls from VB .NET for tighter integration with 'custom' solutions
behind the drawing.
Or am I totally off mark here?
Michael
"Joe Winchester" <winchest@uk.ibm.com> schreef in bericht
news:3FBD303F.2EF6913B@uk.ibm.com...
> Hi Chris,
it,
One
techniques
so
> > screen?
one
device's
> Best regards,
> Joe
Re: JSP/HTML [message #3787 is a reply to message #2640] Fri, 21 November 2003 09:03 Go to previous messageGo to next message
Originally posted by: mendelgili.netscape.net
There is a bean model (the center of the universe for VE). For every
widget (or bean) instance there is an EditPart associated with it, as
well as a live instance on the target VM. The target VM can get the
bounds of these instances, as well as listen for changes. The EditPart
associated with an instance will reflect the image on the canvas.
Pascal Rapicault wrote:
> Thank you,
> PaScaL
> "Joe Winchester" <winchest@uk.ibm.com> a écrit dans le message de news:
>>Hi Chris,
> it,
> One
> techniques
> so
>>>screen?
> one
> device's
>>Best regards,
>>Joe
Re: JSP/HTML [message #3813 is a reply to message #3780] Fri, 21 November 2003 10:10 Go to previous messageGo to next message
Hi Michael,
When you as a developer create a GUI you do stuff like create a frame, put some
buttons on it, etc...
A GUI builder has to do likewise, but it has a slightly different angle. It
doesn't want the button to be a real button that can be pushed, or a text field
to be a real one that can accept keyboard and mouse entry. It wants to show the
user the button and text so they can be previewed based on their initial state.
Two options:
1 - Create the controls (buttons, text fields, etc...) in the IDE itself
so they are owned by a workspace window and actually part of the Eclipse JVM.
You have to then fake out the controls so they don't act as live instances
accepting keyboard and mouse, deal with things like not being able to put a top
level window inside another window so the user can't truly preview things like a
titlebar or maximize/minimize bars, and also deal with the fact that if the user
is modifying the controls at the same time they're using them you have to be
able to unload the class or find another way to sandbox it.
2 - All of the options in 1 are soluble if you do run the widgets inside
the IDE, however another approach which is used by GUI builders (including the
Visual Editor) is to run the controls in a separate JVM entirely. You put them
off screen and hide them from the user as much as you can, and then inside the
IDE you just draw them. This has its disadvantages too over 1, however if it
can be got to work it does offer the ability to draw the GUI any way you want.
You could zoom it, shrink it, draw GridBagLayout controls actually in a grid
with spaces between them. It's sort of like a drawing of a house where in some
modes you want to see the finished result, but in others you want to see the
windows and doors separated out and details of the pipes. The latter kind of
thing is what I was sort of trying to describe when I talked about leveraging
the fact that the Visual Editor is a cartoon layout of the GUI.
Joe
Re: JSP/HTML [message #3886 is a reply to message #3813] Sun, 23 November 2003 23:43 Go to previous messageGo to next message
Originally posted by: scheglov_ke.nlmk.ru
[cut]
Joe, can you please point to classes that create these images and send
them to Eclipse JVM? Ideally just class or package names.
SY, Kosta.
Re: JSP/HTML [message #4336 is a reply to message #3886] Mon, 24 November 2003 10:16 Go to previous messageGo to next message
Hi Kosta,
In the IDE
org.eclipse.ve.internal.jfc.core.ComponentManager
org.eclipse.ve.internal.jfc.core.ImageDataCollector
In the targer VM
org.eclipse.ve.internal.jfc.vm.ComponentManager
org.eclipse.ve.internal.jfc.vm.ImageDataCollector
Joe
Re: JSP/HTML [message #4821 is a reply to message #4336] Tue, 25 November 2003 00:17 Go to previous message
> In the IDE
> In the targer VM
Thank you.
SY, Kosta.
Re: JSP/HTML [message #567676 is a reply to message #2550] Thu, 20 November 2003 16:21 Go to previous message
Hi Chris,
> screen?
Joe
Re: JSP/HTML [message #567720 is a reply to message #2582] Thu, 20 November 2003 20:05 Go to previous message
Thank you,
PaScaL
Re: JSP/HTML [message #567949 is a reply to message #2582] Fri, 21 November 2003 08:51 Go to previous message
Joe,
user...
<clip>
One
techniques
so
</clip>
environment?
behind the drawing.
Michael
> Hi Chris,
it,
One
techniques
so
> > screen?
one
device's
> Best regards,
> Joe
Re: JSP/HTML [message #567992 is a reply to message #2640] Fri, 21 November 2003 09:03 Go to previous message
> Thank you,
> PaScaL
>>Hi Chris,
> it,
> One
> techniques
> so
>>>screen?
> one
> device's
>>Best regards,
>>Joe
Re: JSP/HTML [message #568105 is a reply to message #3780] Fri, 21 November 2003 10:10 Go to previous message
Hi Michael,
Two options:
Joe
Re: JSP/HTML [message #568511 is a reply to message #3813] Sun, 23 November 2003 23:43 Go to previous message
[cut]
SY, Kosta.
Re: JSP/HTML [message #568760 is a reply to message #3886] Mon, 24 November 2003 10:16 Go to previous message
Hi Kosta,
In the IDE
In the targer VM
Joe
Re: JSP/HTML [message #568949 is a reply to message #4336] Tue, 25 November 2003 00:17 Go to previous message
> In the IDE
> In the targer VM
Thank you.
SY, Kosta.
Previous Topic:Some questions
Next Topic:JDialogs vs JFrames behaviours
Current Time: Wed Oct 15 11:20:53 EDT 2025
Powered by FUDForum. Page generated in 0.28330 seconds
