Eclipse 3.1 + Creole 1.1.4 [message #293356] |
Fri, 21 October 2005 11:57 |
Originally posted by: patrick.gelin.rpn.ch
I installed Creole plugin but it doesn't work...
It seems like 'AWT' is needed, is it a plugin? Where do i downloa it?
The error exception is:
java.lang.RuntimeException: Cannot create AWT Frame
ca.uvic.csr.shrimp.ShrimpCorePlugin.ShrimpCorePlugin.createE mbeddedFrame(ShrimpCorePlugin.java:113)
ca.uvic.csr.shrimp.ShrimpCorePlugin.AbstractAWTViewPart.crea tePartControl(AbstractAWTViewPart.java:71)
ca.uvic.csr.shrimp.ShrimpCorePlugin.AbstractToolViewPart.cre atePartControl(AbstractToolViewPart.java:41)
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:305)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:180)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:552)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:28 3)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:51 2)
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:126)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:391)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1102)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:591)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:528)
org.eclipse.ui.internal.PartSashContainer.createControl(Part SashContainer.java:485)
org.eclipse.ui.internal.PerspectiveHelper.activate(Perspecti veHelper.java:230)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.j ava:813)
org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPa ge.java:2165)
at org.eclipse.ui.internal.WorkbenchWindow$5.run(WorkbenchWindo w.java:2356)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.WorkbenchWindow.setActivePage(Workbe nchWindow.java:2338)
org.eclipse.ui.internal.WorkbenchWindow.restoreState(Workben chWindow.java:1861)
at org.eclipse.ui.internal.Workbench.doRestoreState(Workbench.j ava:2566)
at org.eclipse.ui.internal.Workbench.access$14(Workbench.java:2 515)
at org.eclipse.ui.internal.Workbench$19.run(Workbench.java:1514 )
at org.eclipse.ui.internal.Workbench$16.run(Workbench.java:1263 )
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:346)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:291)
org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.java:447)
org.eclipse.ui.internal.Workbench.runStartupWithProgress(Wor kbench.java:1258)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1512)
at org.eclipse.ui.internal.Workbench.access$12(Workbench.java:1 491)
at org.eclipse.ui.internal.Workbench$17.run(Workbench.java:1374 )
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1318)
org.eclipse.ui.internal.WorkbenchConfigurer.restoreState(Wor kbenchConfigurer.java:183)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:700)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1034)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1636)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Thanks for your help.
FUDForum. Page generated in 0.03866 seconds
