| Can't start Eclipse after upgrading (3.1 to 3.1.1) [message #293041] |
Sun, 16 October 2005 13:51  |
I recently upgraded Eclipse to version 3.1.1 using the instructions on the
following page:
http://www.eclipse.org/eclipse/platform-releng/updatesfor3.1 .1.html
... now I can't start Eclipse ...
Please Help.
Here is the log output -
!SESSION 2005-10-16 19:47:41.766
eclipse.buildId=I20050513-1415
java.version=1.5.0_04
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_ZA
Command-line arguments: -os win32 -ws win32 -arch x86 -clean
!ENTRY org.eclipse.osgi 2005-10-16 19:47:55.856
!MESSAGE Application error
!STACK 1
java.lang.VerifyError: class org.eclipse.ui.commands.AbstractHandler
overrides final method .
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.d efineClass(DefaultClassLoader.java:370)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.defineCl ass(EclipseClassLoader.java:233)
org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.f indClassImpl(DefaultClassLoader.java:343)
org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.f indClass(DefaultClassLoader.java:235)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. findLocalClass(AbstractClassLoader.java:183)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.basicFin dLocalClass(EclipseClassLoader.java:141)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:68)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:337)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:389)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:350)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:78)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
org.eclipse.ui.internal.handlers.HandlerPersistence.readHand lerSubmissionsFromCommandsExtensionPoint(HandlerPersistence. java:570)
org.eclipse.ui.internal.handlers.HandlerPersistence.read(Han dlerPersistence.java:257)
org.eclipse.ui.internal.handlers.HandlerService.readRegistry (HandlerService.java:104)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:959)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1636)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:330 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:274)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!ENTRY org.eclipse.osgi 2005-10-16 19:47:55.886
!MESSAGE Bundle update@plugins/org.eclipse.ui.ide_3.1.0.jar [3] was not
resolved.
!SUBENTRY 1 org.eclipse.osgi 2005-10-16 19:47:55.886
!MESSAGE Bundle update@plugins/org.eclipse.ui.ide_3.1.1.jar was picked
instead.
!ENTRY org.eclipse.osgi 2005-10-16 19:47:55.916
!MESSAGE Bundle update@plugins/org.eclipse.ant.ui_3.1.0.jar [4] was not
resolved.
!SUBENTRY 1 org.eclipse.osgi 2005-10-16 19:47:55.916
!MESSAGE Bundle update@plugins/org.eclipse.ant.ui_3.1.1.jar was picked
instead.
!ENTRY org.eclipse.osgi 2005-10-16 19:47:55.926
!MESSAGE Bundle update@plugins/org.eclipse.pde.ui_3.1.0.jar [7] was not
resolved.
!SUBENTRY 1 org.eclipse.osgi 2005-10-16 19:47:55.926
!MESSAGE Bundle update@plugins/org.eclipse.pde.ui_3.1.1.jar was picked
instead.
etc.
| Re: Can't start Eclipse after upgrading (3.1 to 3.1.1) [message #295588 is a reply to message #293179] |
Sat, 03 December 2005 11:36  |
Thanks for your help, Douglas.
I'm sorry it took me so long to reply.
I ended up having to replace some JDT packages as well.
Take care,
_da.
Douglas Pollock wrote:
> darkangel wrote:
>>I get the feeling that that class somehow became corrupt during the
>>update process. I think (I really don't know much) it could be fixed by
>>replacing that file. Could you maybe send this file to me? I tried
>>compiling the java file in CVS, but received two error messages.
> Try running with "-clean".
> If it still persists, I would recommend downloading Eclipse again. I know
> it will take a while on your modem, but there's not much I can do. You
> only really need to replace "org.eclipse.core.commands" and
> "org.eclipse.ui.workbench" for this particular problem. You might try just
> downloading the "Platform Runtime Binary", and extracting the pieces you
> need.
> d.
FUDForum. Page generated in 0.04603 seconds
