multiple masterpages (page orientation) [message #292523] |
Mon, 28 January 2008 09:12 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: rick.unknown.com
My report contains 2 master pages, one for landscape and one for portrait.
Using the page break on the tables I've set the portrait masterpage for
the first table and the landscape masterpage for the second table. This
works flawlessly in the local report viewer.
But when i use the web viewer(deployed in tomcat) suddenly de transition
from portrait to landscape happens on the wrong page, somewhere halfway
the first table.
Birt version(both local as on the server) is 2.2.1.1
According to the manual the itext jar is used for pdf generation. Both on
the server as local version 1.5.2 is used. (itext-1.5.2.jar).
Any ideas what could be causing this difference?
funny thing is that the reports that have multiple masterpages(both for
landscape as portrait) cause these errors in the server logs:
21-jan-2008 16:59:17 org.eclipse.birt.report.engine.data.dte.DataPresen
tationEngine doExecuteQuery
SEVERE: Can't load the report query
Again, in the local report designer these errors don't occur.
Re: multiple masterpages (page orientation) [message #292544 is a reply to message #292523] |
Mon, 28 January 2008 21:50 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Rick,
Can you log a bugzilla entry for this?
Jason
Rick wrote:
> the first table.
> on the server as local version 1.5.2 is used. (itext-1.5.2.jar).
Re: multiple masterpages (page orientation) [message #315849 is a reply to message #292523] |
Mon, 28 January 2008 21:50 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Rick,
Jason
Rick wrote:
> the first table.
Re: multiple masterpages (page orientation) [message #316236 is a reply to message #292523] |
Rick,
Jason
Rick wrote:
> the first table.
FUDForum. Page generated in 0.04247 seconds
