Re: hover hyperlinks on control key [message #291470 is a reply to message #291462] |
Fri, 16 September 2005 10:04 |
Originally posted by: torkildr.resheim.no
Tim wrote:
> I would like to implement in my customized editor the same behavior in
> Java editor where you hold down the control key and hover over a name, a
> hyperlink appears that links to the declaration of the object. Is this
> feature openly available in the API? If so could someone show me an
> example? Thanks.
Implement your own IHyperlinkDetector and IHyperlink then override
getHyperlinkDetectors in your source viewer configuration. Note that
Eclipse 3.1 is required.
Med vennlig hilsen / Kind regards ((
Torkild Ulvøy Resheim, Senior Systemutvikler / Software Engineer ))
Emma EDB AS, Trondheim, Norway. http://www.emmaedb.no |----|_
Private pages: http://resheim.no - "Any sufficiently advanced | | )
bug is indistinguishable from a feature." |____|'
FUDForum. Page generated in 0.03688 seconds
