Connection refused: Running Junit plugin tests. [message #291075] |
Wed, 07 September 2005 13:42 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: VMarathe.ifmc.sdps.org
Hi All,
While invoking test cases under my own application, I am getting a
following exception. I am issuing the below command at command line.
This is the replica of how I invoke plugin test cases on my Eclipse IDE.
I have learnt that JUnitRunner is trying to connect to this port for
sending its results. This test works fine when invoked using Eclipse
IDE. Does it not work with command line. It uses same eclipse
installation as the IDE when invoked through command line. Is there any
other way to accomplish this?
java.net.ConnectException: Connection refused: connect
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(Unknown Source)
at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at java.net.Socket.<init>(Unknown Source)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.conne ct(RemoteTestRunner.java:754)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:336)
org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunne r.main(RemotePluginTestRunner.java:57)
org.eclipse.pde.internal.junit.runtime.UITestApplication$1.r un(UITestApplication.java:99)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3057)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2716)
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
Vasant.
Re: Connection refused: Running Junit plugin tests. [message #291576 is a reply to message #291075] |
Tue, 20 September 2005 13:16 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hi All,
I would like to post this message again, just to check in case anyone
has solution to it.
Appreciate your help,
Vasant.
Vasant wrote:
> Hi All,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Vasant.
FUDForum. Page generated in 0.03495 seconds
