Home » Archived » GEF3D » A couple of errors in ..draw3d
Re: A couple of errors in ..draw3d [message #2622 is a reply to message #2534] |
Fri, 29 May 2009 20:41 |
Hi Miles,
yes, there were indeed some changes with GEF 2.5, some methods were
added to the Graphics interface. I will ask Kristian about that
problem, he has implemented the GEF3D Graphics implementation.
Cheers
Jens
On 2009-05-29 01:38:01 +0200, Miles Parker <milesparker@gmail.com> said:
> OK, I added these lines to each of the three bad files:
> public float getLineWidthFloat() {
> return getLineWidth();
> public void setLineMiterLimit(float miterLimit) {
> // ignored
> public void setLineWidthFloat(float width) {
> // ignored
> Now the diaSample works (it draws noise at first but on resize it
> works) but for the others I get:
> java.lang.RuntimeException: The class: class
> org.eclipse.draw3d.graphics3d.lwjgl.graphics.LwjglGraphics has not
> implemented this new graphics function
> at org.eclipse.draw2d.Graphics.throwNotImplemented(Graphics.jav a:993)
> at org.eclipse.draw2d.Graphics.setAntialias(Graphics.java:798)
> at org.eclipse.draw2d.Shape.paintFigure(Shape.java:94)
> at org.eclipse.draw2d.Figure.paint(Figure.java:1049)
> at
> org.eclipse.gef3d.examples.graph.editor.figures.EdgeFigure2D .paint(EdgeFigure2D.java:44)
org.eclipse.draw2d.Figure.paintChildren(Figure.java:1087)
> org.eclipse.draw2d.Figure.paintClientArea(Figure.java:1119)
> at org.eclipse.draw2d.Figure.paint(Figure.java:1051)
> at org.eclipse.draw2d.ConnectionLayer.paint(ConnectionLayer.jav a:64)
> at org.eclipse.draw3d.Figure3DHelper.paintChildren2D(Figure3DHe lper.java:571)
> at org.eclipse.draw3d.Figure3DHelper.paintChildren(Figure3DHelp er.java:478)
> at org.eclipse.draw3d.Figure3D.paintChildren(Figure3D.java:502)
> at org.eclipse.draw2d.Figure.paintClientArea(Figure.java:1114)
> at org.eclipse.draw3d.Figure3D.paint(Figure3D.java:479)
> at org.eclipse.draw3d.Figure3DHelper.paintChildren3D(Figure3DHe lper.java:599)
> at org.eclipse.draw3d.Figure3DHelper.paintChildren(Figure3DHelp er.java:479)
> at org.eclipse.draw2d.Figure.paintChildren(Figure.java:1087)
> at org.eclipse.draw2d.Figure.paintClientArea(Figure.java:1119)
> at
> org.eclipse.gef3d.editparts.ScalableFreeformRootEditPart3D$1 .paint(ScalableFreeformRootEditPart3D.java:47)
> at
> org.eclipse.draw2d.ScalableFreeformLayeredPane.paintClientAr ea(ScalableFreeformLayeredPane.java:61)
> at org.eclipse.draw2d.Viewport.paintClientArea(Viewport.java:15 6)
> at org.eclipse.draw3d.Figure3DHelper.paintChildren2D(Figure3DHe lper.java:555)
> at
> org.eclipse.draw3d.LightweightSystem3D$RootFigure3D.paintChi ldren(LightweightSystem3D.java:437)
> org.eclipse.draw3d.LightweightSystem3D$RootFigure3D.paint(Li ghtweightSystem3D.java:408)
org.eclipse.draw2d.DeferredUpdateManager.repairDamage(Deferr edUpdateManager.java:294)
org.eclipse.draw3d.DeferredUpdateManager3D.repairDamage(Defe rredUpdateManager3D.java:60)
org.eclipse.draw3d.PickingUpdateManager3D.repairDamage(Picki ngUpdateManager3D.java:75)
org.eclipse.draw2d.DeferredUpdateManager.performUpdate(Defer redUpdateManager.java:181)
org.eclipse.gef3d.ui.parts.GraphicalViewer3DImpl.render(Grap hicalViewer3DImpl.java:159)
org.eclipse.gef3d.preferences.ScenePreferenceListener.start( ScenePreferenceListener.java:138)
org.eclipse.gef3d.ui.parts.GraphicalEditor3DWithPalette.doRe gisterToScene(GraphicalEditor3DWithPalette.java:84)
org.eclipse.gef3d.ui.parts.GraphicalEditor3DWithPalette.crea teGraphicalViewer(GraphicalEditor3DWithPalette.java:72)
org.eclipse.gef.ui.parts.GraphicalEditorWithPalette.createPa rtControl(GraphicalEditorWithPalette.java:62)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:662)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:462)
> org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:286)
> org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2857)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2762)
> org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:2754)
> at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2705)
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
> at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2701)
> at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2685)
> at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2676)
> at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
> at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
> at
> org.eclipse.ui.wizards.newresource.BasicNewFileResourceWizar d.performFinish(BasicNewFileResourceWizard.java:111)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:752)
> org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:373)
> at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:624)
> at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
> at org.eclipse.swt.widgets.Display.sendEvent(Display.java:3544)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1246)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1269)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1254)
> at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1 075)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3442)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3101)
> at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
> at org.eclipse.jface.window.Window.open(Window.java:801)
> at
> org.eclipse.ui.internal.actions.NewWizardShortcutAction.run( NewWizardShortcutAction.java:135)
org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
> org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
java.lang.reflect.Method.invoke(Method.java:597)
> org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
> at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
> On 2009-05-28 16:24:19 -0700, Miles Parker <milesparker@gmail.com> said:
>> Same issue in LwjglGraphics. This looks like its actually due to an API
>> breaking change in GEF 3.5. I'll make the obvious changes and post them
>> back here.
>> On 2009-05-28 16:04:58 -0700, Miles Parker <milesparker@gmail.com> said:
>>> Ideas?
>>> Description Resource Path Location Type
>>> The type DummyGraphics must implement the inherited abstract method
>>> Graphics.getLineWidthFloat() DummyGraphics.java /org.eclipse.draw3d/src/java/org/eclipse/draw3d line
>>> 35 Java Problem
>>> Graphics.setLineMiterLimit(float) DummyGraphics.java /org.eclipse.draw3d/src/java/org/eclipse/draw3d line
>>> 35 Java Problem
>>> Graphics.setLineWidthFloat(float) DummyGraphics.java /org.eclipse.draw3d/src/java/org/eclipse/draw3d line
>>> 35 Java Problem
>>> The type LogGraphics must implement the inherited abstract method
>>> Graphics.getLineWidthFloat() LogGraphics.java /org.eclipse.draw3d/src/java/org/eclipse/draw3d/util line
>>> 40 Java Problem
>>> Graphics.setLineMiterLimit(float) LogGraphics.java /org.eclipse.draw3d/src/java/org/eclipse/draw3d/util line
>>> 40 Java Problem
>>> Graphics.setLineWidthFloat(float) LogGraphics.java /org.eclipse.draw3d/src/java/org/eclipse/draw3d/util line
>>> 40 Java Problem
Re: A couple of errors in ..draw3d [message #2706 is a reply to message #2622] |
Fri, 29 May 2009 22:26 |
Miles Parker Messages: 1341 Registered: July 2009 |
Cool. One more change I needed. In both Lwjgl (awkward name!) and
DummyGraphics, he'll need to do something like:
public void setAntialias(int value) {
public void setLineAttributes(LineAttributes attributes) {
To avoid a graphics exception.
On 2009-05-29 13:41:52 -0700, Jens v.P. <developer@jevopi.de> said:
> Hi Miles,
> Cheers
> Jens
>> // ignored
>> // ignored
>> at
>> at
>> at
>> at
>> at
>> at
>> Method)
>> at
>>> back here.
>>>> Ideas?
>>>> 35 Java Problem
>>>> 35 Java Problem
>>>> 35 Java Problem
>>>> 40 Java Problem
>>>> 40 Java Problem
>>>> 40 Java Problem
Re: A couple of errors in ..draw3d [message #3795 is a reply to message #3751] |
Sun, 31 May 2009 12:45 |
Kristian Duske Messages: 64 Registered: July 2009 |
Member |
Hi again,
I just implemented some of the missing advanced graphics functions on
DummyGraphics, LogGraphics and LwjglGraphics. The remaining
unimplemented functions are
Graphics#drawPath(org.eclipse.swt.graphics.Path)
Graphics#drawText(String, org.eclipse.draw2d.geometry.Point, int)
Graphics#drawText(String, int, int, int)
Graphics#drawTextLayout(org.eclipse.swt.graphics.TextLayout, int, int)
Graphics#drawTextLayout(org.eclipse.swt.graphics.TextLayout, int, int, int,
int, Color, Color)
Graphics#fillPath(org.eclipse.swt.graphics.Path)
Graphics#setClip(org.eclipse.swt.graphics.Path)
These functions make use of platform dependent resources (Path,
TextLayout, Pattern) and are not trivial to implement. I am not sure if
it is possible at all to implement this functionality without changing
the clients of Graphics as well, because I don't see how I can access
the information contained in the platform dependent resources in a
platform independent way.
The only way I see right now would be to subclass Path, TextLayout and
Pattern and write implementations that can use GL to emulate this
functionality, but as I stated above, this would require modifying
client code. Another way would be to get the SWT team interested in
GLGraphics and add GL implementations of those classes to SWT directly.
But even then, I'd have to implement a lot of this functionality by
hand. For example, GL doesn't support paths as clipping regions (only
planes can be used and paths can contain arcs and curves) - I'd have to
write the clipping code for clipping paths by hand.
I hope for now that no existing GEF editor uses these features so that
we won't need to implement them for a while.
Best regards
Kristian
Re: A couple of errors in ..draw3d [message #3830 is a reply to message #3809] |
Mon, 01 June 2009 11:57 |
Member |
Hello Miles,
> Just general issues with rendering which are probably down to some kind
> of eclipse upate issues. For xampel, when I first open a diagram its
> all noise; as soon as I force a re-render by rezizing it looks fine.
> And I am often getting into a state where the workbench is completely
> messed up -- views are redrawn properly, etc.. but I think this is
> because I've stolen the SWT /rendering thread somewhere in my model ->
> view updating code. I'm still figuring out how to do the updates in a
> nice fail-safe way.
Would you mind filing a bug for the garbled display (noise) problem in
our bugzilla, which you can find on this page:
http://www.eclipse.org/projects/project_summary.php?projecti d=technology.gef3d
Please attach a screenshot and, very important, the following information:
Operating System (if Windows, which SPs are installed, if Linux, which
kernel version)
Video hardware (Manufacturer, model, version)
Video driver (Custom or from manufacturer, version)
Maybe I can reproduce the problem and fix it.
Regarding updates, I plan on looking into the update manager and update
mechanism in general myself as well. I think there are some problems
hidden in that code, too. If you find anything, please let us know.
Kristian
Re: A couple of errors in ..draw3d [message #3837 is a reply to message #3830] |
Mon, 01 June 2009 16:58 |
Will do!
On 2009-06-01 04:57:47 -0700, Kristian Duske
<kristian.duske@fernuni-hagen.de> said:
> Hello Miles,
>> nice fail-safe way.
> kernel version)
> Regards
> Kristian
Re: A couple of errors in ..draw3d [message #561398 is a reply to message #2534] |
Hi Miles,
Cheers
Jens
> // ignored
> // ignored
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
>> back here.
>>> Ideas?
>>> 35 Java Problem
>>> 35 Java Problem
>>> 35 Java Problem
>>> 40 Java Problem
>>> 40 Java Problem
>>> 40 Java Problem
Re: A couple of errors in ..draw3d [message #561457 is a reply to message #2622] |
> Hi Miles,
> Cheers
> Jens
>> // ignored
>> // ignored
>> at
>> at
>> at
>> at
>> at
>> at
>> Method)
>> at
>>> back here.
>>>> Ideas?
>>>> 35 Java Problem
>>>> 35 Java Problem
>>>> 35 Java Problem
>>>> 40 Java Problem
>>>> 40 Java Problem
>>>> 40 Java Problem
Re: A couple of errors in ..draw3d [message #561587 is a reply to message #3751] |
Member |
Hi again,
int, Color, Color)
Best regards
Kristian
Re: A couple of errors in ..draw3d [message #561683 is a reply to message #3809] |
Member |
Hello Miles,
> nice fail-safe way.
kernel version)
Kristian
Re: A couple of errors in ..draw3d [message #561700 is a reply to message #3830] |
Will do!
> Hello Miles,
>> nice fail-safe way.
> kernel version)
> Regards
> Kristian
Current Time: Fri Oct 18 02:52:05 GMT 2024
Powered by FUDForum. Page generated in 0.05567 seconds
