Home » Eclipse Projects » Eclipse Platform » Pathological Performance Problem with MarkerUtilities
Pathological Performance Problem with MarkerUtilities [message #287196] Mon, 27 June 2005 09:10 Go to next message
I've apparently done something seriously wrong here ...
Using Eclipse 3.1RC2 on WindowsXP Pro SP2
We're building a feature from a number of plugins which manipulates
files on a remote system which exposes its file system by something
very much like SAMBA.
We have our own project wizard which adds files to our projects by
creating links to the remote files in order to cope with odd
permission and file-naming practices on the remote system.
Up 'til last Friday, everything seemed to be working just fine; we
can open, edit, update and save the files, and all other Eclipse file
manipulations seem to work as we hoped they would.
While working on a routine for adding markers to our files, I found
performance to be very bad. I created a "simple" project and linked
in the same file and saw no performance problem at all.
Running a network monitor while accessing the file in our own project
I saw this troubling behavior:
For each marker I added, the real file on the remote system was
opened, the first line of the file was read one.byte.at.a.time and
the file was then closed. This was repeated each time a new marker
was added, regardless of what line the marker was on, and regardless
of whether the file was open in an editor in Eclipse. As you might
imagine, this is painfully slow.
Performing the same operation on the same file open in a simple
project, I saw no network I/O whatsoever.
What in the world have I done to produce this bizarre behavior?
Where do I start looking?
Bert Hyman | Unisys - Roseville MN
bert.hyman@unisys.com | (651) 635-7791 | net2: 524-7791
Re: Pathological Performance Problem with MarkerUtilities [message #287213 is a reply to message #287196] Mon, 27 June 2005 11:32 Go to previous messageGo to next message
Originally posted by: chaves-do-not-spam.inf.ufsc.br
Creating markers does not depend on the contents of the file in any way,
so this is indeed very strange.
Since your setup is so unusual, in order to figure out what is going on
you would have to do some more debugging yourself. I suggest running
Eclipse from Eclipse (a runtime workbench) in debug mode. Put a breakpoint
in your code before you call the API you think is causing the problem, and
keeping an eye on your network monitor log, step through the code.
Rafael
Re: Pathological Performance Problem with MarkerUtilities [message #287216 is a reply to message #287196] Mon, 27 June 2005 11:44 Go to previous messageGo to next message
Originally posted by: wharley.bea.com
"Bert Hyman" <bert.hyman@unisys.com> wrote in message
news:Xns968253140E186VeebleFetzer@206.191.52.34...
> the file was then closed. [...]
Sounds like the sort of behavior that would happen if something were trying
to decide whether the file were binary or text? Maybe that's a clue, dunno.
Re: Pathological Performance Problem with MarkerUtilities [message #287221 is a reply to message #287216] Mon, 27 June 2005 13:40 Go to previous messageGo to next message
wharley@bea.com (Walter Harley) wrote in
news:d9p6sl$i6g$1@news.eclipse.org:
> were trying to decide whether the file were binary or text? Maybe
That was it.
We had attached the C Nature (org.eclipse.cdt.core.cnature) to our
project so that anybody editing a C program file would get the
benefit of the C outline.
Unfortunately the CDT attaches a resource change listener which looks
at the target file on every resource change event (adding a marker
being one) and reads the first few bytes of the file to see if it's
binary.
So, we're currently weighing the benefit of supplying the C outline
vs. the cost of opening/reading/closing the file on each and every
marker. Or maybe some other way to stop the check on resource
changes.
This does suggest that people doing C development on non-local files
might see some unexpected network traffic.
Re: Pathological Performance Problem with MarkerUtilities [message #287239 is a reply to message #287221] Mon, 27 June 2005 20:31 Go to previous messageGo to next message
Originally posted by: bob.objfac.com
Whatever else you do, please file a bug report against CDT. I'm sure
they'd like to know they're doing something so silly.
Bob
> That was it.
> binary.
> changes.
Re: Pathological Performance Problem with MarkerUtilities [message #287280 is a reply to message #287239] Tue, 28 June 2005 14:57 Go to previous messageGo to next message
bob@objfac.com (Bob Foster) wrote in
news:d9q5pj$ogb$1@news.eclipse.org:
> sure they'd like to know they're doing something so silly.
On further investigation, it's not quite as bad as I thought at
first.
This binary check is only performed on files the CDT doesn't
recognize as "its own".
I'm toying with the idea of extending cdt.core.CFileTypeAssociation
to declare all of our file types as honorary C source files. But,
who knows what horrible side effects ->that would have.
>>>>and the file was then closed. [...]
>> That was it.
>> looks at the target file on every resource change event (adding a
>> marker being one) and reads the first few bytes of the file to see
>> if it's binary.
>> outline vs. the cost of opening/reading/closing the file on each
>> and every marker. Or maybe some other way to stop the check on
>> resource changes.
>> files might see some unexpected network traffic.
Re: Pathological Performance Problem with MarkerUtilities [message #287437 is a reply to message #287280] Wed, 29 June 2005 19:47 Go to previous message
It's still pretty awful.
Bob
> first.
>>>That was it.
>>>if it's binary.
>>>resource changes.
Previous Topic:Can you programmatically add Tasks to the TaskList?
Next Topic:3.1 RC1 to 3.1 Release external classpath problem
Current Time: Wed Oct 22 03:57:17 EDT 2025
Powered by FUDForum. Page generated in 0.04359 seconds
