Home » Eclipse Projects » Eclipse Platform » Version number in .eclipseextension file
Version number in .eclipseextension file [message #287144] Fri, 24 June 2005 13:12 Go to next message
I have a question about the version number in ".eclipseextension" file in
the Extension Location: what is this version number used for? I tried to
create an extension location for Eclipse3.1 RC2, so the version number
inside of ".eclipseextension" is '3.1.0'. But I can add this extension
location to Eclipse 3.0. If I change this version number to '2.1.0', I can
add this extension location to Eclipse 3.1 RC2. Is this version number
used to do something?
J.
Re: Version number in .eclipseextension file [message #287163 is a reply to message #287144] Fri, 24 June 2005 18:44 Go to previous messageGo to next message
"J.Li" <jli1@us.ibm.com> wrote in message
news:32247107057e4fd5402b30df6d4b1299$1@www.eclipse.org...
In fact, AFAIK, nothing of this file content is used at all.
You can leave the file empty entirely, unless someone tells the contrary
The code that checks for that file does that:
// check the marker
File marker = new File(eclipse, ".eclipseextension"); //$NON-NLS-1$
if (!marker.exists() || marker.isDirectory())
return null;
return eclipse;
Never reads it.
Re: Version number in .eclipseextension file [message #287167 is a reply to message #287144] Fri, 24 June 2005 19:39 Go to previous message
Just to add something: if you use the update manager and ask for a feature
to be installed in some other location, the update manager will religiously
create an eclispeextension file with all the fields matching those of the
installed product.
id=org.eclipse.platform
name=Eclipse Platform
version=3.1.0
But it is ignored AFAIK.
Previous Topic:./eclipse versus java -jar startup.jar
Next Topic:Why I can't see the icon on the button
Current Time: Fri Oct 17 02:50:01 EDT 2025
Powered by FUDForum. Page generated in 0.03818 seconds
